Upgrading RA fuel pump
Old Jul 31, 2011 | 10:55 PM
pbassist12's Avatar
Needed or is the OEM fine?
Old Jul 31, 2011 | 11:03 PM
omegis's Avatar
Someone correct me if I'm wrong, but pretty sure X fuel pump is same as RA pump.
If that's the case:
https://www.evolutionm.net/forums/ev...fuel-pump.html
Based off that link, you should be fine even with an X turbo swap. Probably could change the injectors though since they're PnP.
Old Jul 31, 2011 | 11:21 PM
pbassist12's Avatar
I didnt know that the RA has the same as the evo X. I have a turboback exhaust, evo x fmic, UR IC piping and UR intake. Im getting a custom tune and that should do it for engine mods for a while. If the stock fuel pump can handle that without going 100% ill be happy
Old Aug 1, 2011 | 03:04 AM
El-Diablo's Avatar
Most upgrades go for Walbro pump and there is also a green relay that is meant to be more reliable than the stock relay
Old Aug 1, 2011 | 07:36 AM
pbassist12's Avatar
Well if i dont need to upgrade i would rather spend that money somewhere else in my car
Old Aug 1, 2011 | 07:50 AM
bronto11588's Avatar
if those are your mods dont worry about injectors or pump for now you wont be at 100% on either. HOWEVER........change out that POS stock fuel relay and zip tie/safety wire your fuel pressure regulator hose or you will end up like me!
Old Aug 1, 2011 | 08:56 AM
omegis's Avatar
Been preaching that to a lot of people including those over on 9glancers.com
Old Aug 1, 2011 | 03:01 PM
RazorLab's Avatar
OEM RA pump is same as Evo 10 pump.
I used the OEM pump with my CBRD BBX lite turbo on 91 octane, no issues.
Old Aug 1, 2011 | 03:21 PM
pbassist12's Avatar
where can i get those?
So the stock fuel pump and injectors are fine unless i go with a bigger turbo?
Old Aug 1, 2011 | 03:35 PM
omegis's Avatar
www.mitsubishiparts.net has the fuel relay. Just do a search for "fuel relay" on that site.
Yes
Old Aug 1, 2011 | 03:51 PM
pbassist12's Avatar
okay cool, just get that and i should be fine?
Old Aug 1, 2011 | 04:47 PM
omegis's Avatar
If you don't have the blue relay, then yes.
Old Aug 1, 2011 | 05:29 PM
pbassist12's Avatar
and what about the wire?
Old Aug 1, 2011 | 05:32 PM
omegis's Avatar
He's talking about zip-tieing or using safety wire on the part circled "came off here" in the pic below:
As you may have guessed, his hose came off their causing him to run stupid lean.
Old Aug 2, 2011 | 03:50 AM
billyboy1's Avatar
what would be even better is an in-tank anti-surge set up. on long left handers with semis (and under half to a quarter of a tank) often get fuel surge issues...
