What Hardware is Required for Test Pipe Install
Old Sep 7, 2011 | 01:31 PM
p1llar's Avatar
I got my Tsudo test pipe the other day, it looks like it's decent quality. However, there was no gasket or bolts/nuts supplied.
IIRC the stock test pipe connects to the midpipe with 17mm bolts/nuts, I'm thinking I should be able to reuse those.
I'm not sure about the DP to Test Pipe though, I will buy a few 3" Exhaust gaskets but what bolts/nuts should I buy? can I reuse the oem hardware?
Old Sep 7, 2011 | 01:45 PM
sstevojr's Avatar
Two of the bolts are welded into the stock cat, so you definitely need to get at least 2. And make sure that the nuts are compatible w/ whatever bolts you get (or buy matching ones at the same time).
Old Sep 7, 2011 | 02:25 PM
p1llar's Avatar
Right on, do you know what the length was? and 14mm nuts? 17mm again?
Old Sep 8, 2011 | 12:45 PM
zx-319's Avatar
Look at how thick the flange is... The bolt has to be long enough for twice as thick + the nut...
The nut will depend on the bolt you buy... Bring the test pipe with you at Canadian Tire and pick the bolt that fit...
Don't forget to purchase 2 new exhaust gaskets (about 6$ each)...
And I think it's 4 bolts, not 2...
Also, you might need some strength as exhaust bolts tend to rust REALLY fast so they might be difficult to take off if you are using a floor jack or don't have enough place to extend your tools with a pipe...
Old Sep 8, 2011 | 01:47 PM
p1llar's Avatar
Cool thanks.
My car is only a month old so the bolts shouldn't be hard to take off, they weren't too bad when i did my catback two weeks ago.
drakedeming
For Sale - Cars For Sale
May 9, 2017 03:10 PM
drakedeming
May 4, 2017 05:25 AM
BDecker9
Jul 27, 2016 11:28 AM
DropThatHammer
57
Mar 3, 2016 07:04 PM
lbcevo
Oct 2, 2015 08:33 AM
