Fuel Cut
Old Sep 29, 2011 | 09:47 AM
kradovich's Avatar
Fuel Cut
I have a huge problem and looking for advise. I have an 09 RA with AMS intercooler and piping, AMS boost pill and ECU flash, a turboxs down pipe and turboxs high flow cat. Ever since putting in the downpipe and high flow cat at full throttle and at about 3G rpm's I am getting a bad popping or almost backfire sound coming from the motor. I assume I need a tune but dont know if I should get a Cobb accessport and do it myself or have it professionally done. Should I wait to install my intake and cat back and manual boost controller or get it done first? Or is there anything I can do to help with it? Don't know if it's fuel cut or not? Anyone with advise?
Old Sep 29, 2011 | 12:34 PM
SudzRA's Avatar
Does it pop under acceleration or after you let off the gas/shift gears? If it's popping under acceleration, there's a problem. If it's when you're off the gas or shifting, it's just because you're running rich, which is normal. Mine does that when I let off the gas from time to time. A tune is never a bad idea, however. Spend the money at a reputable tuning shop in your area, and put on the rest of your mods at that time.
Old Sep 29, 2011 | 01:16 PM
kradovich's Avatar
Yeah it happens under full throttle not when I back off, I'm ordering the cat back tonight and the intake soon after, then taking it to EFI logics in Danbury Connecticut. I heard rumors that the popping could be fuel cut or boost cut bit I have no idea, it happened after I installed the downpipe and high flow cat
Old Sep 29, 2011 | 02:07 PM
sstevojr's Avatar
I'd speculate that the engine is dumping a TON of fuel trying to compensate for your mods (still stock tune yes?). As such, once it leans out a bit all the un-burnt fuel sticking to the HFC is finally undergoing combustion....in your exhaust....
Get a tune. You live in NY? Plenty of good shops on the East Coast.
Old Sep 29, 2011 | 02:08 PM
sstevojr's Avatar
FYI, fuel cut is when you hit your RPM limit and the ECU cuts off fuel (hence the name).
Old Sep 29, 2011 | 03:13 PM
kradovich's Avatar
Thanks I'll get the tune once I install the intake and exhaust, I'll update after hopefully the problem goes away
Old Sep 29, 2011 | 05:15 PM
robertg's Avatar
I have the same exhaust, but a CP-E intercooler and at one point an AMS boost pill which I ultimately didn't use once I had a tune. Yes that is backfire your getting, normal for me after the tune. I got the tune right away so I wasn't running around with the mods without a tune.
My recommendation for a shop hands down is to go to Krazy House Customs in northern NJ, Petey Turbo is the man you want to do the tune.
Old Sep 29, 2011 | 07:47 PM
Crazems's Avatar
Are u losing power and car bucking while boosted? If so I had that problem after my turbo swap. It was my spark plugs
Old Sep 30, 2011 | 04:59 AM
kradovich's Avatar
I checked my plugs they are fine, I even looked up the E3 plugs but he don't make it for this motor yet. I'm losing power but its not bucking
Old Sep 30, 2011 | 09:07 AM
SudzRA's Avatar
I wouldn't bother with plugs other than the NGK ones specified for the RA or Evo X (depending on the turbo you're running). E3 plugs are a bit of a gimmick imho.
Old Sep 30, 2011 | 09:39 AM
robertg's Avatar
BTW - Plugs for RA and EVO X are the same, so don't matter which turbo.
Old Sep 30, 2011 | 11:57 AM
SudzRA's Avatar
True for 2009MY Ralliarts, built up to and including November 2008. All RAs built after November 2008 use plugs one step hotter, heat range 7 (as opposed to Evo X plugs, heat range 8).
Old Sep 30, 2011 | 04:27 PM
Crazems's Avatar
Not true. Thought the same thing. I checked part numbers they are different. I guess Evo are colder. Both NHL iridium tho.
Old Oct 1, 2011 | 05:01 AM
robertg's Avatar
Pulled a plug from a 2008 EVO X GSR and my 2009 RA, same stock plugs including the part number. I've been running the plugs for at least 20k miles now, no issues.
I ordered these plugs at one point but was given the ones on the left in the photo below. I used the ones on the right.
LEFT - 1822A063 NGK ILKR7E6
RIGHT - 1822A021 NGK ILKR8E6
Old Oct 1, 2011 | 07:02 AM
SudzRA's Avatar
Looks like Mitsu provided you with the 'new' sparkplug that they switched to for the RA. I have no idea why they decided to go to a hotter plug.
