Upgraded RA Turbo by FP
Subscribe
Oct 28, 2011 | 02:56 PM
That's not right, there is no way in hell the lag is that long on a TD04, unless your tuner was cockoo-for-cocopuffs
Reply 0
Oct 28, 2011 | 02:57 PM
The HTA wheel might be different from the one I have. Like I said this was about 2 years ago. My base line was 200hp.
Reply 0
Oct 28, 2011 | 05:28 PM
since we were mentioned-
you can contact us for details-
our upgrade flows similar to an evo X turbo, but spools faster---
the idea was a cost effective STOCK evo X power level without changing manifolds turbos, intakes, outlet pipes, downpipes, etc
cb
Reply 0
Oct 28, 2011 | 05:53 PM
Quote: That's not right, there is no way in hell the lag is that long on a TD04, unless your tuner was cockoo-for-cocopuffs
Chris from Ams tuned the car so I don't know what to say. CBRD makes great products and there customer service is top notch.
Reply 0
Oct 28, 2011 | 06:36 PM
Maybe the scale is off on the chart??? When you floor it, does it take until 4300rpm to hit peak torque (even the bigger X turbo can do it by 3300)?
Reply 0
Oct 28, 2011 | 06:44 PM
Pm'ed
Reply 0
Oct 28, 2011 | 07:22 PM
How much does something like this cost? Im looking to tune up my RA turbo.
Reply 0
Oct 28, 2011 | 08:29 PM
The FP RA turbo upgrade is $795. Tune will run $300-500 depending where you go. Not sure about installation though but shouldn't be too bad to do it yourself if you know what you're doing.
Take in to consideration down time for your car also.
Reply 0
Oct 28, 2011 | 09:18 PM
Silthos, I expected you to hit at least over 300 with the turbo upgrade and supporting mods/bolt-ons. Any track numbers at all like 1/4 mile? Thats interesting
For example with my mods - Boost pill, K&N drop-in, 3 inch catback, High flow cat, Evo X intercooler and piping, plus future 800cc injectors, blacqops fuel pump on 93 octane and then the turbo upgrade from CBRD using the RAD, and considering my elevation to be below sea level, can it be assumed I will be at least at 300WHP with a proper tune from say Chad or Bryan? Imagine adding some cams and springs too.
Reply 0
Oct 28, 2011 | 09:33 PM
Its a low reading Dyno. A stock 06 gto dyno'ed 300hp to the wheels the same day. No 1/4 mile time.
Reply 0
Oct 29, 2011 | 10:24 AM
Silthos peak numbers are great:
(262-200)/262= 23.66% gain
The only thing that looks weird to me is WHEN his power occurs. It's about 1200rpm to the right??? From FP's email, it sounds like they upgrade the compressor wheel to flow more air. So if the turbine is still the same small size it "should" spool instantly, just like the stock RA turbo. But for some reason it's got the lag of a FP Red (which is ~4300-4500 rpm)...
Silthos, just answer this one question, when you get on the gas, does it take until +4000rpm to hit peak torque?? Compared to stock you would notice this as a HUGE difference.
EDIT: Small math error corrected ;p
Reply 0
Oct 29, 2011 | 11:03 AM
When I smash on it, the car moves. Its not like my friends Evo x with an fp red where I can feel some lag.
Reply 0
Oct 30, 2011 | 08:13 PM
So what's the update? Is it best to stick with the STOCK RA turbo FP'd or get something like Stock X turbo or FP Green? Possible?
Reply 0
Oct 30, 2011 | 08:48 PM
Just depends on what your goal is. Personally I'm doing an fp red swap in the next couple of weeks.
Reply 0
Oct 31, 2011 | 11:16 AM
Quote: 43lb flow rate - not bad as the rad turbs is 38, too late for me but would be good to see the results that this upgraded turbo goes
The wheel is rated at 43lb/min that does NOT mean the turbo will flow 43 lb/min... The RAD number of 38 lb/min is based on actual logged flow rate.
Reply 0
