Cel: P0171
Old Dec 5, 2011 | 02:54 PM
pbassist12's Avatar
Cel: P0171
After I got tuned, ive had the CEL pop up a few times and after a while it will go off. Is it a bad tune or what that could be causing the CEL. Ive gotten the CEL a few times but I only scanned it twice at autozone and got the same code and the light popped up again today driving home so im assuming its the same code. Anyone else get this code?
P0171
System too lean - cylinders 1-4
Old Dec 5, 2011 | 03:17 PM
2muchboost's Avatar
Ive been getting the same code after my tune. Car runs strong and shows no signs of knock. From the searching Ive done it seems to be a common thing with cars that have upgraded intakes and tunes. I will however be going back to my tuner just so he can double check everything.
Old Dec 5, 2011 | 03:42 PM
pbassist12's Avatar
okay cause i went back and he looked at the code and he said that the mitsubishi cats sometimes like to reset and show a code or something like that. i cant remember the exact thing he said
Old Dec 5, 2011 | 04:00 PM
p1llar's Avatar
That code should be unrelated to.the cat, whatre your mods?
Do you have an a/f gauge?
Old Dec 5, 2011 | 04:04 PM
RazorLab's Avatar
That is from fuel trims too positive. Either the tune needs to be adjusted or something mechanical changed.
Nothing to do with a cat.
Old Dec 5, 2011 | 09:24 PM
pbassist12's Avatar
My mods are posted in my sig. Im getting an A/F gauge for xmas so hopefully I can monitor it myself
Old Dec 5, 2011 | 09:25 PM
pbassist12's Avatar
so should the shop retune it for free or what?
Old Dec 6, 2011 | 12:10 AM
2muchboost's Avatar
If it has to do with fuel trims and nothing was changed on your car then yes the shop should fix it no charge.
Old Dec 6, 2011 | 11:29 AM
pbassist12's Avatar
okay should i go there even if the CEL goes off?
Old Dec 6, 2011 | 11:53 AM
TOralliart's Avatar
I got that error before after Bryan@gst tuned me? I didn't notice anything odd with the AFRs from my gauge. Bryan modified the tune and it went away.
Old Dec 6, 2011 | 04:15 PM
user 7082023424's Avatar
Vac line from the FPR?... That caused my last P0171...
Old Dec 8, 2011 | 07:30 AM
03chi-town0Z's Avatar
Did your tuner rescale the maf? The car can be running perfectly, but because it's not doing what the car expects to see, it throws a code.
Old Dec 8, 2011 | 08:10 AM
evo_soul's Avatar
Use your scan tool to see when the freeze frame of the error occured. See what the car was doing. That will give you and your tuner a hint of where to look next. If you dont have a A/F gauge, I would recommend buying one for your own peace of mind when your driving you car.
Old Dec 8, 2011 | 11:54 AM
pbassist12's Avatar
I'm getting one for Xmas so soon enough!
Old Dec 8, 2011 | 12:10 PM
RazorLab's Avatar
Don't need a scan tool, I already stated what triggers it in post #5.
mrm95
Nov 7, 2014 01:04 PM
mikebuff35
Aug 29, 2014 09:13 AM
fapers
Lancer Troubleshooting
Aug 19, 2011 10:16 AM
goodhart
Jul 19, 2011 03:51 AM
sykou
Oct 24, 2007 07:47 AM
