Dyno graph
Old Feb 14, 2012 | 05:14 PM
masafina's Avatar
Dyno graph
I want to share the chart to know your opinions, remember I am a beginner with ecuflash. it may be better but I'm new. "google translator"
Old Feb 14, 2012 | 05:30 PM
sstevojr's Avatar
Did you run into a brick wall? Why does torque suddenly drop off?
Old Feb 14, 2012 | 05:34 PM
masafina's Avatar
I dropped the throttle before stopping the dyno
Old Feb 20, 2012 | 12:49 PM
masafina's Avatar
something I can fix there???
Old Feb 20, 2012 | 01:24 PM
sstevojr's Avatar
I wasn't talking about the end of the pull, I'm referring to the 4k rpm line (I think that's what it is, no labels). See how you spool up nice and strong, hit peak torque.....and then fall on your face. Something is not right there. Either you are hitting boost error correction, or possibly an unfinished part of your timing map???
Old Feb 20, 2012 | 02:10 PM
masafina's Avatar
oh ok, that part is because Im not very familiar with the boost tables and there are 28psi but drop to 22 and stay there.
Old Feb 20, 2012 | 02:22 PM
sstevojr's Avatar
That would be the first thing to fix. 28psi is a bit much for pump gas, but just the same you are over shooting your target (either load or psi, depending on which method you use) and it's causing a downward error correction. If you smoothed that out I can see you gaining 30whp/40wtq at least right at that spot.
Old Mar 5, 2012 | 08:21 AM
masafina's Avatar
can you help me ???
I want 26psi and hold, not 28 and drop to 22 like you see in the graph.what tables I need to change?
thanks for your time
Old Mar 5, 2012 | 08:29 AM
Kracka's Avatar
No offense, but here is the best advice you're going to get all year, and it could potentially save you thousands of dollars: Pay a professional for a tune. That chart makes it very obvious you don't a clue how to properly tune a car. There is a reason that many of us that actually do know how to street-tune a car still pay a professional to dyno-tune it.
Old Mar 5, 2012 | 08:52 AM
bossssman38's Avatar
Originally Posted by masafina
can you help me ???
Just get a pro tune. You're playing with fire.
Old Mar 5, 2012 | 09:41 AM
Exyia's Avatar
can you help me ???
too many "bad" tuners/tuner shops think tuning Evo's (esp with SST's) are just boost and fuel - tuning a 4b11t takes WAY more than that
if you're even confused about those two, I would just pay to have it professionally tuned
Old Mar 5, 2012 | 09:47 AM
ambystom01's Avatar
Why does the graph go back on itself? You have two different power levels at the same RPM point (I assume the X axis is RPM). Get someone professional to tune it.
Old Mar 5, 2012 | 09:57 AM
Integra9807's Avatar
Bump.......
Old Mar 5, 2012 | 10:04 AM
ambystom01's Avatar
Originally Posted by Integra9807
Bump.......
Why the **** are you bumping a thread that was commented in a few minutes ago?
Oh wait, I know, because you're spamming the ****ing forum with bumps.
https://www.evolutionm.net/forums/se...rchid=17329769
I hope a mod sees this and deletes your useless posts.
Old Mar 5, 2012 | 10:29 AM
sstevojr's Avatar
Agree. Your torque is a bit out of control to see a vertical line like that (is that rpm on the horizontal?), then it falls on it's face hard. You are seriously risking a very expensive repair bill.
