Gear Slip + White Puff Of Smoke
I was rolling in first and hammered it. The gear slipped going into second and made the rev limiter bounce a couple times. When it did shift, there was a cloud of white exhaust.
Everything seems ok and it sounds normal driving.
Is this just a build up from being at the rev limiter?
Black smoke - Fuel Burning / Rich A/F
Blue smoke - Oil Burning
White smoke - Coolant burning/trans fluid
If the smoke doesn't go away after the engines warmed up then you have a problem.
Nah.
I suspect it was raw fuel burning in the Cat as a result of the ignition cutoff (redline exceedence event) but not a fuel cutoff. As a result excessive fuel was pumped through the cylinders for a brief period.
You reduced the life of the Cat a wee bit... But no worries, eh?
