Exhaust Leaks
Old Sep 20, 2012 | 10:09 AM
Ralliator's Avatar
Exhaust Leaks
I just got a dual exit cpe cat back exhaust from a member on here and I have a few questions. This is my first time doing any exhaust work. So once I had it installed I start it up and go under it to check for leaks and I notice that where the mid-pipe splices into the back section there is a slight leak around where the clamp goes on. Then where the one side of the muffler splices to the other it has a slight leak. Should I try repositioning it or will it be fine?
Also where the midpipe joins the converter there is a leak and there's water dripping out of it. It looks like the converter is rusted a little on the bottom side by the flange. I used the oem gasket that was on it. Should I get a new one?
Old Sep 20, 2012 | 01:48 PM
Ralliator's Avatar
Should I just order a new gasket from cpe?
Old Sep 20, 2012 | 01:55 PM
TurtleRA's Avatar
Had same issues as you, I just went back under and wiggles the muffler as I tightened the bolts, seemed to tighten it up a bit better and then I had no leaks.
Old Sep 20, 2012 | 04:40 PM
Ralliator's Avatar
I went out and loosened the bolts that go into the converter and then tightened them, but somewhere in the process I believe the one bolt crossthreaded and now I'm afraid I may have stripped the threads on either the bolt or the converter or both.
Old Sep 22, 2012 | 01:26 PM
ArtofRalli's Avatar
[QUOTE=Ralliator;10411898]I went out and loosened the bolts that go into the converter and then tightened them, but somewhere in the process I believe the one bolt crossthreaded and now I'm afraid I may have stripped the threads on either the bolt or the converter or both.
best thing to do is to take your car to a exhaust shop and get them 2 finish the job. This should cost you between 35 and 80 dollars tops.
Raptord
Jan 8, 2021 07:41 AM
PolloVagabundo
May 4, 2017 10:46 AM
joonvang
Jan 2, 2017 01:00 PM
Blacksheepdj
Dec 2, 2016 08:31 AM
gkswhdl88
Mar 17, 2015 05:21 PM
