Adding knock CEL
Old Feb 20, 2013 | 02:05 PM
crak's Avatar
Adding knock CEL
All I have to do is add the data below to my metadata ROM and edit the values to enable CEL knock? Just trying to figure this out here. I checked to see if other addresses are used by this and none are so is it safe to assume that the tephra mod wont change something it is not supposed to?
<scaling name="ECUTime" units="ms" toexpr="1000*x/102" frexpr="102*x/1000" format="%.0f" min="0" max="100000" inc="10" storagetype="uint16" endian="big"/>
<scaling name="Percent256" units="%" toexpr="100*x/256" frexpr="256*x/100" format="%.1f" min="0" max="100" inc="0.5" storagetype="uint16" endian="big"/>
<table name="Load Required for CEL on Knock" category="TephraXMOD V1" address="fb490" type="1D" scaling="Load"/>
<table name="KnockSum Required for Slow CEL (Low Knock)" category="TephraXMOD V1" address="fb492" type="1D" scaling="uint16"/>
<table name="KnockSum Required for Fast CEL (High Knock)" category="TephraXMOD V1" address="fb494" type="1D" scaling="uint16"/>
<table name="Knock CEL Flash time" category="TephraXMOD V1" address="fb496" type="1D" scaling="ECUTime"/>
Old Feb 20, 2013 | 03:14 PM
richardjh's Avatar
You need to have the TephraXMod ROM itself.
You can't just drop those items into a non-Tephra ROM and set them.
Rich
Old Feb 20, 2013 | 05:27 PM
crak's Avatar
ok thanks rich. do you mind explaining why?
I tried to do the <include>ROM ID</include> but it would not work. I know because its probably all different.
tephra
Mar 31, 2024 01:17 PM
mrfred
Dec 15, 2022 11:13 AM
itzwolf
Mar 15, 2022 06:18 AM
tephra
Nov 22, 2019 10:05 PM
Tuner@Swift
Aug 22, 2008 01:47 PM
