Shifting problems
Old Feb 22, 2013 | 10:58 PM
DjRags604's Avatar
Shifting problems
My 09 Ralliart is completely stock and I keep up to date with maintenance. Currently at 62,000 km/38,000 miles. Over the last week I've noticed that when left in auto/normal (boring, I know) the transmission is shifting later than it normally does. I try to stay out of boost during stop/go traffic and usually the car will shift around 2500 rpm in to the next gear. Now I'm noticing that its closer to 2700-2900 rpm before it will shift. Shifts feel a bit harder as well when I put the car into manual mode. Anyone have this problem or have any advice?
Old Feb 22, 2013 | 11:26 PM
majinfajita's Avatar
Have you done your Evo3 service (the one that incl. transmission fluid and filter change) yet?
Old Feb 23, 2013 | 12:41 PM
crak's Avatar
the car will shift gears before boost if you keep the throttle low. thats normal.
but did you do what majinfajita ask?
Old Feb 24, 2013 | 07:31 PM
szuto's Avatar
I notice that the car has been shifting a bit late also but, it's from the cold weather here in Toronto.
Old Feb 25, 2013 | 06:58 PM
DjRags604's Avatar
Yes I did the change about 10,000 km ago. However, they did not change the filter (the dealership said they did not perform this service) only the fluids. And yes I know it will shift before boost if you keep the throttle low which is why I said it would usually shift around 2500 rpm. However, it seems like it needs more revs lately in order to shift. As for temp, it's finally rising here in Vancouver so I have to say that it's likely not the cold (current averages is around 6C/43F).
Old Mar 4, 2013 | 04:04 PM
hixlancer's Avatar
Veteran: Army
I would do a flush and change that filter! It's expensive but when I did mine all problems ceased and felt like a brand new tranny again
root@localhost
Feb 9, 2014 10:40 AM
Simmons
Nov 2, 2013 08:46 AM
JCEVOVII
Oct 23, 2013 05:04 PM
total0wnage
Mar 14, 2011 02:01 AM
Thoe99
12
Feb 21, 2005 07:53 PM
