Stock Ralliart BOV
Old Mar 17, 2014 | 05:42 PM
danike's Avatar
Stock Ralliart BOV
Does the stock BOV need upgraded for any performance benefit? Examples: Stock Catalytic Converter = most restriction or Stock Intercooler = subsatisfactory cooling after extended uses or stock air filter = poor design?
Does anyone have any gripes about the stock BOV?
Old Mar 17, 2014 | 06:01 PM
Slee256's Avatar
Yeah, it's a plastic P.O.S.
Old Mar 17, 2014 | 07:35 PM
mattnshell's Avatar
I bought one is my friends EVO x bpv. Looks better than plastic but u won't see any real performance from it
Old Mar 18, 2014 | 06:34 AM
Jay10Ralliart's Avatar
FCOTM Winner
The evo x bpv holds higher boost and doesnt leak like the crappy stock plastic one.
Old Mar 18, 2014 | 08:40 AM
Veronica's Avatar
Not an issue until you tune and then start to exceed stock RA boost levels. As you approach EVO X boost levels - then you need an EVO X BOV...
Old Mar 18, 2014 | 08:43 AM
danike's Avatar
Will I be close to Evo X boost levels with a AMS boost pill and GST BM+BP+TBE map?
Old Mar 18, 2014 | 09:35 AM
Exige90's Avatar
You should be well on your way there, if not there, with those mods. I have just the BP and tune, and I got an Evo X one just to be sturdy. I have noticed that it's more steady and reliable, as it doesn't leak nearly as much as the plastic one did, if at all.
Old Mar 18, 2014 | 10:19 AM
AmsRalliart's Avatar
First thing when I got my RA I swapped out the stock one for the HKS ssqv3 and found that it holds boost at a steady 10lbs stock and now it holds 21lbs to redline whith my set up that I have now
Old Mar 18, 2014 | 10:29 AM
danike's Avatar
Since there are no used Evo Bov's being sold on this site or ebay, what other BOV should I get?
Old Mar 18, 2014 | 11:31 AM
Exige90's Avatar
the Synapse DV is the best, from what I've been hearing. I have no proof of this, but just from customer reaction and popularity.
Old Mar 19, 2014 | 09:50 AM
Veronica's Avatar
EVO IX work just as well
Old Mar 19, 2014 | 10:41 AM
danike's Avatar
Just picked up an Evo X from a member on this forum. Thanks!
Old Mar 20, 2014 | 06:56 PM
Hughett's Avatar
I actually Broke the nipple off the plastic stock bov while replacing it with one from the evo x. My boost is no where near the threshold for needing an upgrades bov, but I'm with the other guys in that it's cheap plastic and it's better piece of mind to just upgrade.
Having many 2g turbo eclipses, I saw all to well how the cheap plastic bov's fail and leak over time!
Old Mar 21, 2014 | 04:52 AM
danike's Avatar
Will there be any noise difference between the plastic and metal bov's?
Old Mar 21, 2014 | 06:10 AM
Exige90's Avatar
Not really. It might be a LITTLE louder, but I can't really tell a difference. I also did it just for the sake of better efficiency. Leaks are bad!
