idk whats going on
Old Nov 19, 2014 | 09:33 PM
11RalliArt_em's Avatar
idk whats going on
So i did quite a few bolt on mods to the Ralliart. Prior to the additional parts i just got installed i had these...
AEM Intake (+15hp)
Turbosmart BOV (+25hp)
TurboXS turbo-back exhaust
Cobb AccessPort with a Stage 2 flash
i will throw out there i have 84xxx on a 2011 Ralliart. But in the monitoring gauges of the AccessPort..i was only seeing max boost at 11.xx psi. Ive seen videos and posts here on forums of people getting max 14psi. I don't know much about turbos as this is the first vehicle I've ever done serious engine mods too. My first turbo owned vehicle as well.
So the guys at DynoTech Tuning installed the following yesterday
Cobb 3-Port EBCS
Mishimoto Intercooler
Ultimate Racing UICP/LICP (+10-15hp)<---combined with the IC
Now i know when buying aftermarket parts, everyone claims you will see XXhp gains. Most is attainable but i don't rely on getting that right away with out more modifications,proper tuning. But, i did the math and for what those claim as gains, it added up to +55hp. Base hp as most know is 237hp. With what i have done id expect to be at 285-290hp WITH a tune.
They ran the dyno, everything installed and the EBCS would only boost at 10psi. baseline was 180whp. They spoke to Cobb and they said there should be most boost etc etc. They hooked up a manual boost controller and got 14psi of boost. with that boost, they saw about 225-230hp. There is no leaks as they tested for all that. They're going to put in a new controller (manual) tomorrow and tweak it to 18psi sp I'm hoping there will be bigger gains but whats not making sense is how I've lost 60hp from stock. Could this be a result of wear and tare on the turbo or is there a bigger problem? Anyone else had similar experiences?
Old Nov 20, 2014 | 02:51 AM
richardjh's Avatar
Boost is power.
10psi boost with a bunch of bolt-ons is about as useful as taking a stock RA and unplugging the 2-port boost controller. Wastegate pressure isn't where you want to be.
18psi boost is about where a stock RA will momentarily boost to (on a coolish day)... not at high RPM - it drops off fast. I have no clue where in the RPM band yours touched 18psi...
...but it indicates a boost control issue, yes. Mechanical, tuning, wiring, piping... something.
They'll track it down quickly, I'm sure.
Rich
Old Nov 20, 2014 | 08:04 AM
Veronica's Avatar
...and look at some other baseline dynos - the 'advertised' 230HP is at the crank. Dyno measures at the wheels (drivetrain losses mean a lower number always...)
See the GST thread for before and after and to set a target for a good tune. If your tuner can't beat the GST basemap - why are you paying them money?
Old Nov 20, 2014 | 11:14 AM
I figured there would be some loss of HP with a difference of awhp and chp but 60hp? I didn't expect that. That's really what's baffling me at this point. Hopefully they can figure it out
Old Nov 20, 2014 | 03:15 PM
kornkid42's Avatar
A stock Ralliart measures around 190-200 whp on a dyno. Once you get your boost issue fixed, with your mods and a good tune, you should be at 260-270whp on a dyno.
As far as "this part = this much hp gain", you will see very little change without a proper tune.
Old Nov 28, 2014 | 02:14 PM
I took it to the dyno to have it custom tuned.
The problem he ran into was the ECBS isn't adding any boost with the upgrades after flashing. The car is still running at what the WG puts out (ranges from 9-12psi). Im trying to solve this problem, i was thinking maybe there is no voltage going to the factory harness but i don't know what pin(s) on the edu would control that.
Can anyone give some insight on ways to tackle this issue?
Old Dec 27, 2014 | 08:17 AM
Rralliart09's Avatar
Ever find out what the problem was???
Old Dec 28, 2014 | 09:09 AM
Nope. I Have to take it to the dealership. I got a fault code for the AWC and I think the code is causing an issue. I've been trying to figure out if my extended warranty will cover this part so it's become a process 😕
Old Dec 28, 2014 | 10:06 AM
Ralliart09er's Avatar
A boost leak test still wouldn't be a bad idea... also the SST is terrible with power loss. Figure 20% loss is what I've been told. Also, could've sworn the ralliarts, at least the 2009-10's, were at 13.2 psi stock.
Old Dec 29, 2014 | 07:35 AM
Yea the shop said they did a boost leak test and there was no leakage.
Old Feb 8, 2015 | 07:56 AM
RalliFast's Avatar
check the AEM intake
I had the same problem when I installed my AEM intake, actually everyone seems to have this problem.
In the pipe leading from the turbo to the airbox on of the holes is NOT drilled all the way through, hence your boost controlled stock or aftermarket won't know what's going on in the intake...
Take it off drill the whole out and enjoy 24 psi
bigern2006
Lancer Engine Management / Tuning Forums
16
Sep 2, 2007 09:09 PM
Steve@NoLimitmotors
May 17, 2007 10:21 PM
Zippo41189
Nov 13, 2006 06:38 PM
03LaNcErES
Jul 24, 2004 08:22 PM
