What spark plugs for 93+boost pill+tbe gst map?
What spark plugs should I truly be using with the GST 93+BP+TBE tune? I also have a K&N drop in filter. I put the EVO X plugs in it and it seems to run fine, but I am wondering what other have done or used and what are their opinions. Thank you in advance.
Hiya.
Evo X plugs should be absolutely fine.
Note that early AUS market Ralliarts (eg. 2009, like mine) came with the exact same plugs as Evo X anyway. Other region markets may well have been the same. In later years, Mitsubishi obviously decided it was overkill/expensive that way, and changed the Ralliart plug choice a bit.
Rich
Rich
My 09 Ralliart came with the EvoX plugs already installed. Your choice based on your mods are fine IMO.
how do you know when to change plug temperature anyhow?
i've just finished getting tuned and was told my turbo is basically maxed out with my mods and tune...
there must a definitive point when you need to select a specific heat range?
DjRags604
Jan 30, 2015 09:29 AM
bwanner
Aug 31, 2012 05:38 PM
mfp5011
11
Jun 17, 2010 11:55 AM
Noize
Evo X Dyno Results
14
Apr 13, 2009 06:22 PM
