Boost?
Your end goals and competency working on cars decides that.
If you want a 28 psi evo x turbo monster than you would replaces a plethora of parts.
If you wants a 20 psi mild tune you can do that with an EBCS.
You should not be worrying about "adjusting" boost but rather figuring out where the boost you are making is going. As stated before 9/10 its going to be a loose hose on the UICP, or LICP. It sounds like your car was modded pretty good then they traded it in, took off a bunch of stuff and did a **** job reinstalling their stock parts.
I agree,
That's why I'm saying he need to not worry about more and start worrying where the leak is...they are mutually exclusive concepts as one pertains to performance and his problem is a maintenance thing.
so I had a smoke test done and all the lines for the turbo are connected and good can someone explain the wastegate the auto shop said they think the boost is coming from the wastegate
Do some googling on parts of a turbo system that will help you figure it out.
FWIW I just had to replace my wastegate actuator, ask the shop to tighten down the Wastegate actuator(WGA) arm as much as they can and see if your boost gets a little better.
I would lean toward another leak being there.
go over every boost and boost signal line there is and see what you find I'm certain you will find a plethora of little leaks biting you in the *** right now.
It's 18-19 peak psi on a stock Ralliart. Look at post #13 in this thread and Razorlab posted a graph that shows you the numbers right there in black & white.
One more - find the leak(s).
Take the gauge out of the system and see if the car pulls harder. If so - it too is leaking.
Replace the BOV and then (only then) try another waste gate actuator. WGA doesn't really fail (none I am aware of).
