Boost?
Old Mar 21, 2016 | 11:05 AM
  #31
Lanart2011's Avatar
Found the leak now I'm pulling 17psi on vacuum and 18 on psi
Originally Posted by Veronica
One more - find the leak(s).
Take the gauge out of the system and see if the car pulls harder. If so - it too is leaking.
Replace the BOV and then (only then) try another waste gate actuator. WGA doesn't really fail (none I am aware of).
Old Mar 21, 2016 | 01:34 PM
  #32
RazorLab's Avatar
How many people need to tell you what stock boost is before you realize what stock boost is?
Old Mar 21, 2016 | 04:40 PM
  #33
Lanart2011's Avatar
I know what stock boost is I was telling her what I was getting after I fixed the leak not asking what the boost should be so calm the hell down
Old Mar 21, 2016 | 05:03 PM
  #34
RazorLab's Avatar
Great way to get us to help you Mr. McOverlyDefensivePants!
You know what stock boost is because I showed you. Then you asked a couple more times, then another person told you. Then you finally saw it for yourself when you fixed the problem and THEN it finally sunk in.
Good luck in the future with everything!
Old Mar 22, 2016 | 11:50 AM
  #35
Veronica's Avatar
Good!
Did I miss it? What was the fix?
bwanner
Aug 31, 2012 05:38 PM
wingnut
Jan 20, 2005 11:11 AM
blue beast
Mar 29, 2004 02:52 PM
