Unplugging the wastegate solenoid?
Subscribe
Mar 26, 2016 | 07:32 AM
Quote: Can you take a photo?
I'll try to take a pic today
Reply 0
Mar 26, 2016 | 02:00 PM
i tried to ad a pic razorlab but it won't put the pic in when I add the pic it changes it to something else
Reply 0
Mar 27, 2016 | 09:05 AM
okay can you explain the "T" going into the solenoid then? One hose off the solenoid should go to the hose assembly I referenced and one should go to the intake tube.
Reply 0
Mar 27, 2016 | 04:46 PM
where the hose plugs into the solenoid my hose has a t fitting just before the solenoid and is capped off
Reply 0
Mar 27, 2016 | 05:24 PM
You are really going to have to get me a photo. Sounds like your lines are anything but stock. I'm curious if you even still have the oem boost pill still in there. Can you check using the photo I posted as reference?
Reply 0
Mar 27, 2016 | 06:08 PM
Quote: You are really going to have to get me a photo. Sounds like your lines are anything but stock. I'm curious if you even still have the oem boost pill still in there. Can you check using the photo I posted as reference?
Reply 0
Mar 27, 2016 | 06:13 PM
Do you have an email I can send the pics I took to
Reply 0
Subscribe
