Unplugging the wastegate solenoid?
Old Mar 23, 2016 | 02:53 AM
Lanart2011's Avatar
I am having an issue with inconsistent boost I talked to Cobb and they said it sounded like the wastegate solenoid I read an older post where people was talking about unplugging their (BCS) and was getting more consistent boost are these the same thing and if not what would happen if I unplug my wastegate solenoid's harness would I need to cap off the 2 vacuum lines S well?
Old Mar 24, 2016 | 06:37 AM
Veronica's Avatar
No, do not unplug the waste gate actuator.
If is not building boost consistently - replace the waste gate actuator assy. If it is not holding boost - replace the BOV with an EVO X (or EVO IX) one.
Old Mar 24, 2016 | 12:07 PM
Lanart2011's Avatar
it holds boost
Im just way under boosted I'm peaking at 9.5 at wot
I unplugged the harness to the wastegate solenoid and made a pass but nothing changed still peak at 9.5ibs
Old Mar 25, 2016 | 07:53 AM
Veronica's Avatar
Have you done a boost leak check yet?
Old Mar 25, 2016 | 08:17 AM
RazorLab's Avatar
Are you trolling? You made a thread here about the same thing last week and that you fixed it already
https://www.evolutionm.net/forums/09...l#post11592413
Old Mar 25, 2016 | 08:26 AM
Lanart2011's Avatar
I have fixed the boost leak but still am not getting more then 10ibs of boost peak I read a thread about unplugging the wastegate solenoid but I was still only getting 10ibs at peak boost so it's not a boost leak like everyone said I've had Mitsubishi do a pressure and vacuum test and a smoke test
And like I said before 18psi vacuum
10psi boost the chart I was shown on the other post said 17-18 ibs of boost so what else can it be
Old Mar 25, 2016 | 08:28 AM
RazorLab's Avatar
You said it's making 18psi and 17 in vac in that link. Is that not true?
Did you buy the car used?
Old Mar 25, 2016 | 10:01 AM
Lanart2011's Avatar
[QUOTE=razorlab;11594465]You said it's making 18psi and 17 in vac in that link. Is that not true
Yes I bought the car used it was a one owner car
When I replaced all the hoses and lines and took it out the first time it hit 18psi and 17 vac once then the psi dropped to 10 and has remained the same
Old Mar 25, 2016 | 10:21 AM
RazorLab's Avatar
What hoses and lines did you replace? Did you replace the boost solenoid hose assembly?
Do you have it hooked up like this?
Old Mar 25, 2016 | 08:30 PM
Lanart2011's Avatar
Yes the only difference is where there are 2 lines going into the solenoid I have one with a T that is capped off
Old Mar 25, 2016 | 08:33 PM
Lanart2011's Avatar
I don't know if it's the guage or not but I've noticed here the last couple of days when my boost guage does hit 10psi on peak the needle is wiggling back and forth rapidly from 9.5-11 while I'm in high RPM'S above 4K
Old Mar 25, 2016 | 08:42 PM
RazorLab's Avatar
Can you take a photo?
Old Mar 26, 2016 | 02:40 AM
roni4g63's Avatar
you can buy a 3 port, retune and be dine with it? are you on oem solenoid?
roni4g63's Avatar
flapper
also, check the wastegate flapper for looseness
Old Mar 26, 2016 | 07:32 AM
Lanart2011's Avatar
I wanna do a 3 port and pull and tune but the cheapest shop near me says it will cost 1500 for that
