PS Pressure Switch
Old Feb 7, 2017 | 02:36 PM
dfarmer0033's Avatar
PS Pressure Switch
Quick background, Getting code P0551 (PS Pressure Switch Circuit/Performance). I have tried cleaning the connector to no avail. Looking at used pumps to replace. First question, do Ralliarts and Evo X's share the same pump. I read somewhere that it was thought that they do but I can not for the life of me find that thread again. Second, the pressure switch looks as if it can be removed and replaced. Couldn't I buy a used pump and swap the switch on the back to save myself some time? Has anyone ever had an issue like this?
Old Feb 9, 2017 | 08:44 AM
Veronica's Avatar
When I googled the code it said:
http://www.engine-codes.com/p0155_mitsubishi.html
Which is for Faulty Heated Oxygen Sensor (H2OS) Bank 2 Sensor 1...
So what exactly is the problem you are having? Steering or MIL?
Old Feb 9, 2017 | 09:23 AM
I am very sorry. I miss typed the code. The correct code is P0551. The steering works perfect. The code comes and goes as it pleases. I have cleaned the connector on the back of the pump. I am starting to think that the switch is actually going bad. Do you know if the pumps between the RA and X are the same?
Old Feb 10, 2017 | 10:48 AM
Veronica's Avatar
If the steering is fine and is just a faulty switch - I would just ignore it and keep driving...
As to your question - I don't know. I "think" they are common - but I can't prove it.
Old Feb 10, 2017 | 11:11 AM
DWILSON357's Avatar
Evo X Mitsubishi # 4450A137
Ralliart Mitsubishi # 4450A137
Based off of Oemmitsubishiparts.com
Old Feb 13, 2017 | 09:15 PM
You are the greatest superhero of all. Thank you very much
Sn0w Man
Lancer Troubleshooting
Feb 10, 2010 01:48 PM
AlienEvoX
17
Oct 9, 2009 02:17 PM
Nasty Evolution
Jun 28, 2009 11:43 AM
mmartahus
10
Dec 22, 2008 03:06 PM
