Flash Died at 51% now car won't start
Old Mar 8, 2017, 03:52 PM
OhioEVO8's Avatar
I have flashed several times with no issues. Today I had a TBE installed and tried to reflash using the proper basemap. It failed at 51% and wouldn't progress. Now when I try to read from or write to the ECU it fails. Help!
Old Mar 9, 2017, 02:58 PM
DWILSON357's Avatar
Sounds bricked..you will need to recover.next time follow the brick save method.
You basically go through the brick steps when you get the error the first time WITHOUT turning off comp or disconnecting the tactrix.
Old Mar 9, 2017, 06:09 PM
OhioEVO8's Avatar
When you say recover do you mean bench flash it as per the instructions here -> http://www.evoxforums.com/forums/showthread.php?t=29820
Old Mar 10, 2017, 04:27 AM
DWILSON357's Avatar
Yes..if this happens again in the future you can go through the recovery steps in ecu flash, right after your failed communication as l9ng as you have disconnected Ted the tactrix or comp yet.
TreatsIX
Oct 24, 2015 03:20 PM
L888Apex
Oct 30, 2012 07:47 PM
Travisty
Lancer Troubleshooting
Sep 3, 2011 01:18 PM
Joeekrub
Dec 4, 2009 03:43 PM
dafoe69
14
Mar 14, 2007 09:57 PM
Quick Reply: Flash Died at 51% now car won't start
