cant read ecu 53610016
Hi guys
I have a 2009 ralliart and i cant read the ecu
[13:49:58.250] -- unloading kernel --
[13:49:58.250] kernel reset
[13:50:00.379] -- unlocking ECU --
[13:50:00.379] starting session...
[13:50:00.383] requesting seed...
[13:50:00.387] sending key...
[13:50:01.770] -- resetting ECU --
[13:50:03.201] -- reading ECU ID --
[13:50:03.326] ECU HW part number : 1860B107
[13:50:03.342] ECU SW part number : 1860B10705
[13:50:03.372] VIN : JMBLMCX4AAU000344
[13:50:03.376] interface close
[13:50:15.390] using metadata XML ID from file /
[13:50:26.635] saving rom file C:/Users//Desktop/53610016.bin
[13:50:26.663] 1048576 byte image written.
says unknown ecu
i found all versions but number is lower
can anyone create an xml file it?
or can i flash an older file version?
thanks a lot guys
says unknown ecu
thanks a lot guys
Hi there.
Just create a "53610016.xml" with this in it:
That will allow you to reflash that particular ROM image to the vehicle.
[edit]A slightly older version of 5361xxxx should flash just fine. 53610013 is very well supported for tuning (and is the version used in the "GST Base Maps" for 2009/2010 AUS-EDM).
Rich
Code:
<rom>
<romid>
<xmlid>53610016</xmlid>
<internalidaddress>5002a</internalidaddress>
<internalidhex>53610016</internalidhex>
<make>Mitsubishi</make>
<market>EDM</market>
<model>Lancer</model>
<submodel>Ralliart</submodel>
<transmission>SST</transmission>
<year>2010</year>
<flashmethod>mitsucan</flashmethod>
<memmodel>M32186F8</memmodel>
<checksummodule>mitsucan</checksummodule>
</romid>
</rom>
Rich
Hi there,
i have the 53610016 Rom and its not match with the 53610013 xml, diferent wrong tables in Fuel and Timing map. And Mode 23 is "not match".
Rom: 53610016, 2010 EDM Ralliart SST
Can anyone help me? THX
Grip Master
Feb 2, 2013 06:21 PM
MonacoGP
Apr 8, 2011 02:06 PM
