AMS Transmisson Cooler Kit and AMS Exhaust
http://www.amsracingblog.amsperformance.com/
"We have been hard at work developing a very nice trans cooler for the EVO X MR and Ralliart. Using a very high quality Setrab cooler, High quality Fan and OEM like mounting brackets. We hope to retail this right around $500.00 and this should dramatically help out trans temps on the MR and Ralliart." There was a AMS exhaust thread but it disappeared.... http://www.amsperformance.com/cart/A...st-System.html "The AMS Mitsubishi Lancer Ralliart Cat-Back Exhaust System is the most unique exhaust system on the market. It was designed to be used with the same high flow cat, resonated test pipe, or test-pipe used on the Mitsubishi Evolution X. It can also be directly bolted on to the factory catalytic converter. The AMS Ralliart Cat-Back Exhaust System has undergone countless hours of research and development and has been designed to make the most horse power as well as shed serious weight off your Ralliart. Our exhaust features mandrel bent piping for the best exhaust flow. This system does not have any restrictions like other popular exhaust systems that "neck down" and hurt performance. Like all other AMS exhaust products this Cat-Back is TIG welded with 100% 304 stainless components including the flanges and hangers. The system utilizes factory exhaust hangers and includes a high quality slash cut 4" tip muffler. By simply installing this exhaust system you can expect to see as much as 15+ Wheel Horsepower gains over stock without even re-tuning the ECU! Features • 3" throughout entire system. Does not "neck down" like other systems • 100% Stainless Steel construction. No mild steel flanges or hangers • All flanged connections. No band clamps or slip fits to come loose • 15+ Wheel Horsepower gains over stock • 24 lb. weight savings (21 lbs. compared to stock at 45 lbs.) • 6" Of Ground clearance, no lower than the factory cross member • Bolts up to the factory catalytic converter, AMS High-Flow Cat, AMS Resonated Test-Pipe or AMS Test-Pipe • Includes gaskets and hardware (2 bolts and 2 gaskets, re-use 2 stock front bolts) • Unrivaled fit and finish Specifications • 304 Stainless Steel • 3” piping .049” wall thickness • Polished Muffler w/ 4” Cut Tip • 3/8" Thick Stainless Steel flanges • 21 lbs Applications • 2009+ Mitsubishi Lancer Ralliart EMISSIONS STATEMENT: Federal and many state laws prohibit the removal, modification or rendering inoperative any part that affects emissions on motor vehicles used on public streets or highways. Many Automotosports parts are designated for track use or off-road use only. Installation of certain components may bring the vehicle out of compliance with safety and/or emissions standards. Automotosports recommends that vehicles with parts designated in this fashion not be operated on public roads. Automotosports customers are responsible for complying with applicable state and local environmental regulations." Quotes from there Blog and Site. |
Looks like the Tranny Cooler will go where Injen's CAI filter will be placed.
Originally Posted by ReaperSevero
(Post 7241903)
I'm just curious whether something like this could void the warranty on the TC-SST. I guess it could, but it seems kind of silly for something that is, essentially, a preventative measure. |
The exhaust is on their site {thumbup}
I need to know if the Evo X AMS downpipe works with the Ralliart. I think CP-E has the same sort of design for a downpipe and it isn't on back order. Just hate to order my exhaust from two differnt locations but the CP-E Downpipe is half the price.
It just works much better when it's all from the same place. Plus gotta go with the winning team. AMS has delivered time and time again with quality and performance. Wait for it!
Woo cant wait for the tranny cooler! =]
I can't wait for a dual exhaust from someone...
Woot Woot AMS Cat Back!!!! now all we need is Sound Clip!!!
Originally Posted by RotorGlow
(Post 7242782)
I will be getting a sound clip here soon :)
The AMS exhaust thread didn't disappear, it was moved to the proper area, vendor announcements.
We need some installed pics... We wanna see how it loosk and SOUNDs please!!!! lol
I am going to order mine next week if I get the money I should have it by friday.
