HID retrofit?
Old Apr 1, 2010 | 05:47 AM
asperber's Avatar
HID retrofit?
Does anyone know of any decent kits to retrofit a halogen housing to make it a projector? I would like to add HIDs to my 2010 Ralliart, but I don't want it to look crappy or blind other people, so I want to do it right.
Thanks
Old Apr 1, 2010 | 08:24 AM
Taranis's Avatar
Cleanest way is to buy new OEM housings that come with the projectors. They run about 300 a piece I think. Then you will need an HID kit and an D2S bulb adapter I believe. =)
-Taranis
Old Apr 1, 2010 | 12:11 PM
snopro32's Avatar
where can you get the oem housings w/ projectors?
Old Apr 1, 2010 | 02:24 PM
velocityhead's Avatar
Edit: my mistake, posted wrong link. Corrected.
Here ya go: http://www.trademotion.com/partlocat...layCatalogid=0
Old Apr 1, 2010 | 03:44 PM
Taranis's Avatar
Does it say somewhere if those are the projector housings for sure or not? Those are the only assemblies I found on the site as well, but it does not seem to explicitly say if they are projector or not.
-Taranis
Old Apr 1, 2010 | 04:57 PM
initial_d2k's Avatar
They should be halogen housing from the picture ...
just to let everyone knows the Evo X projector seems to be the same as E55 3in one.
Old Apr 1, 2010 | 05:49 PM
r3m1xxralliart's Avatar
^^ is that with the projectors?
Old Apr 2, 2010 | 10:20 AM
Sorry, I posted the wrong link. This is the correct one: http://www.trademotion.com/partlocat...layCatalogid=0
Old Apr 3, 2010 | 09:23 AM
snopro32's Avatar
so this is the whole projector light assembly then?
Old Apr 3, 2010 | 10:49 AM
asperber's Avatar
I found a guy in Long Island, NY that'll do the entire retrofit for around 800, including all parts, and labor (including taking the bumper off to get to the headlights..
Old Apr 3, 2010 | 11:36 AM
I think the link is for the Lens + Shroud only .. you'll still need to bake and replace the thing + get HID kit with connector and custom cover.
Pro:
You'll have a more OEM look
Con:
Too expensive for too little "extra" .. you can get FX-R retrofitted with clear lens for the same price with lifetime warranty ... check out http://www.lightwerkz.net/
Picture: http://www.lightwerkz.net/gallery/ma...g2_itemId=3856
Old Apr 3, 2010 | 05:49 PM
I don't think you'll need to do any baking if you buy the OEM projector housings...you should be able to install directly in place of your halogen housings and use whatever HID ballast you want. I think.
Old Aug 5, 2010 | 11:35 PM
Snake bite's Avatar
where is this guy on long island?
Old Aug 6, 2010 | 06:56 AM
try them:
http://www.lightwerkz.net/index.php
Lancer:
Old Sep 7, 2010 | 06:15 PM
eyekyu's Avatar
use lightwerkz, i got my s2k retro from them. great team and easy to work with.
