Evo x spoiler
When you pop your trunk and raise, you'll see two bolts on either side of the trunk. These hold the OEM wing on. When you remove the bolts, the wing will just pop off. There is some two sided tape underneath, but that isn't an issue. Now you'll be looking at the trunk with two empty holes on either side. To attach the SSS wing, drill out the two holes that allign with the bottom of the SSS mount. They are easy to find, you'll see two layers of metal, and immediately below the pre-drilled holes there is an obvious place to drill the hole. Drop the SSS wing on, and fasten it using only 2 bolts on either side. This will hold up just fine.
The attached pictures are of my Ralliart with the SSS wing installed.
If you order the spoiler through x-factordesign they will give you a free part to go with the car. I chose the rear diffuser that goes on the roof, but it didn't look good. Come to find out they gave me some chrome driving light surrounds too so i guess I got 2 free gifts hahahahahha.
while everyone is on the topic of spoilers, i found this spoiler here, see what everyone else thinks of it i may buy it tho the shipping is hellacious! I do like the spoiler, i have yet to contact them to see if it will fit or if they make ones for our car or not but it does state in the title for lancers& evo's and we do have the same specs as a normal lancer. I really do like this alot and i have not heard or seen anynone yet with this spoiler.
http://cgi.ebay.com/ebaymotors/08-09...Q5fAccessories
everything went wrong i removed the oem spoiler made two scratches on the trunk and then i tried installling the OEM EVO X SSS SPOILER and a piece on the bottom snaped so it basicall broke and now i have to get it fixed does anybody have any ideas on what i should do to get the bottom piece fixed????
[WTB] WW High spoiler
domyz
Feb 22, 2016 07:43 AM
