ECU removal
Old Apr 27, 2011 | 08:51 AM
TrailBrake's Avatar
ECU removal
I have a spare ECU that I'd like to backup the factory settings to via Tactrix cable and OpenPort, but I can't figure out how to detach the original ECU.
Any ideas?
Old Apr 27, 2011 | 09:02 AM
elmerfud54's Avatar
detach that bracket at the top and there a few screws down between the airbox and ecu and also between the ecu and fuse box. then you have to pull back a clamp that connects it to the wiring harness and use a little elbow grease
Old Apr 27, 2011 | 05:25 PM
TrailBrake's Avatar
Thanks for the info. I'll give it a try
Old Apr 27, 2011 | 05:41 PM
RazorLab's Avatar
You won't be able to just plug and play another ECU, just FYI.
Old Apr 27, 2011 | 09:01 PM
elmerfud54's Avatar
i think he plans on flashing the spare ecu and keeping the stock one untouched
Old Apr 27, 2011 | 09:07 PM
RazorLab's Avatar
I know, flashing it won't do much.
Old Apr 27, 2011 | 09:15 PM
elmerfud54's Avatar
out of curiousity what has to be done to get it to work?
Old Apr 28, 2011 | 05:19 AM
TrailBrake's Avatar
The plan is to backup the original ECU's config via EcuFlash. Disconnect original ECU, plug in the spare, then restore the saved configuration.
I'm hoping this will replicate all setting including the immobilizer, so the spare ECU will be a true hot spare.
Old Apr 28, 2011 | 12:18 PM
03chi-town0Z's Avatar
Not going to work that way, AFAIK. When we replace a computer here, we have to mate it through the mitsu MUT-III scan tool and you need to write the vin-coding and key-coding to the ECU which allows it to interact with the ETACS, Immobilizer, and KOS system computers.
If youre doing it for warranty purposes, basically saving your OEM ECU and tuning on the second unit, you could find a dealer willing to do that for you. Then you might be ok, but you'd have a record of that work being performed at a dealership and you'd be pretty screwed anyway unless the dealer was ok with going along and being shady with you keeping it off the record.
Old Apr 28, 2011 | 12:24 PM
RazorLab's Avatar
This is why I said it won't work.
Old Apr 28, 2011 | 05:17 PM
total0wnage's Avatar
I could make that work lol, i used to work at the dealership and im cool with all them. my friend is a tech so i could have him do it after they close or something lol. too bad i already flashed my original ecu
Old Apr 29, 2011 | 07:56 AM
TrailBrake's Avatar
Interesting, thanks for the feedback.
rme0f1
AEM EMS
May 17, 2017 09:28 PM
greddy23
Oct 19, 2016 08:41 AM
jameswwt
Feb 15, 2016 05:59 AM
Ralli_Red
May 4, 2015 09:31 PM
Dakota Evo
Apr 14, 2015 01:48 PM
