How to: Replace front rotors & pads
Old Apr 11, 2012 | 07:53 AM
Heliart's Avatar
Awesome write-up and very clear pictures. Thanks! Will have to replace my pads soon (@ 50,000 miles)....my rotors seem to be ok though. Do you know if they rear brake pistons are the push-in type too or are they the twist-and-push-in type (my 03 Tiburon's were like that) that would require a special tool to get the pistons back in?
Old Apr 11, 2012 | 08:18 AM
Struc's Avatar
They are simply push in type. The "twist and push" type are for cars where the E-brake uses a "screw" inside the caliper to push the caliper piston out, and thus the brake pads against the rotor.
The Ralliart's have a whole separate drum brake assembly inside the disc for the E-brake.
Old Apr 11, 2012 | 11:13 AM
Heliart's Avatar
Cool thanks for the info!
Old Apr 14, 2012 | 10:00 AM
03chi-town0Z's Avatar
Not really relevant to our cars, but if you enounter a car like this, a stout pair of needle-nose pliers and a steady hand will usually get the job done
Old May 10, 2012 | 09:09 AM
Big Steve's Avatar
Thank you for this how-to. I used it last week when I changed my front and rear pads/rotors. It made life a lot easier!
Old May 11, 2012 | 11:22 PM
badchad23's Avatar
same rotors for rear too?
Old May 12, 2012 | 09:42 PM
Struc's Avatar
Pretty much same procedure, but no, the rotors are not the same - at all.
Old May 14, 2012 | 07:14 AM
DatRAzn's Avatar
Excellent write-up, very easy to follow and well document with pictures. .
I'll probably be doing this later this year, @ 64k on OEM pads/rotors still . Surprisingly, they're all still good. I guess I don't drive my car very hard...
Old May 14, 2012 | 10:54 AM
Added to Brake How-to sticky
Old Jun 6, 2012 | 10:15 AM
Veronica's Avatar
...and paint those calipers! Mine looked like sheeit after only two years. :P
Old Jun 25, 2012 | 10:17 AM
tangjuice81's Avatar
Smile Thank you!
Struc, great job! I was looking into EBC brakes, since I like the cross drill rotor look, and better stopping power. Your post will help me out a great deal.
Old Apr 14, 2015 | 09:00 AM
Zippy452's Avatar
Thanks for the great write up. This will be helpful as I haven't really done brakes on a car much. I think last time I had my pads replaced on my last car (my civic before the RA) by a mechanic as it was in for an inspection anyways.
So glad to hear our rear pads are a simple push in type and not the type that requires a tool to turn it in.
Quick questions. I assume that if I am just doing my pads, I can pop them out after I take of the front/top portion of the caliper and hang it with the hanger as you suggested right? Is there a certain method to pop them out. Then it's just using a old bad to squeeze the rotor back in and then popping the new pads in and greasing the back and replacing the top caliper section. Am I correct on all this?
I'm thinking of just picking up some stop tech pads and doing this. Should I just reused the OEM shims or does anyone know if they will come with new shims. I'm gonna repalce all 4 as the fronts are in dyer need and the backs are soon to follow. Rotors look ok for now.
Thanks in advance and sorry for my newbness lol.
Old May 8, 2015 | 09:39 AM
Zippy452's Avatar
bump
honda-guy
May 16, 2023 06:00 PM
Drew314
31
Feb 16, 2020 04:34 PM
Green_Bandit
21
Sep 9, 2019 02:14 PM
CatalystGod
Evo X How Tos / Installations
20
Dec 12, 2016 01:36 AM
o-townFLA
Jan 29, 2009 11:40 PM
