Schroth Harness for the Ralliart
Old Sep 3, 2012 | 08:25 PM
sstevojr's Avatar
Thanks to RRE for the hook-up! These are designed to be direct bolt-on for RA's (and Evo X's).
The kit comes with additional bolts, but here is how I installed mine using stock bolt holes (based on the guidance of Mike W of RRE):
Driver's Seat Belt Bolt (requires a 17mm)
Right Rear Bolt for Driver's Seat (next to center console, requires a 14mm)
Remove the Back Seat (two clips)
Several Bolts to Choose From
Driver's Side Seat-Back (to clear the seat bottom when re-installed; 14mm, the tabs are designed to be "bent" to accommodate tight spaces)
Rear Driver's Side/Center Seat Belt Clips
END RESULT:
DD
READY FOR WORK
Old Sep 3, 2012 | 11:49 PM
neogeo64's Avatar
Nice! These are perfect for DD cars that want to track them once and a while.
Old Sep 4, 2012 | 12:49 AM
ambystom01's Avatar
No roll bar + no 5/6th point= not safe for daily or track use.
Old Sep 4, 2012 | 06:16 AM
Steven_Trujillo's Avatar
He uses the regular seat belt for DD and his 4 point for the track.
Old Sep 4, 2012 | 08:16 AM
ambystom01's Avatar
Also unsafe. A setup like that is only appropriate for autocrossing.
Old Sep 4, 2012 | 01:45 PM
sstevojr's Avatar
Feel free to contact Schroth and explain to them how they are "not safe" or "not appropriate".
There is 1 thing wrong in the pics above, but it's not
Yes a roll bar is an improvement, but not a requirement (although it is something for the future).
http://www.schrothracing.com/store/T...allye/rallye-4
http://www.schrothracing.com/docs/Ra...structions.pdf
Old Sep 4, 2012 | 02:04 PM
Chaz17's Avatar
I like this setup, but I believe amby is correct.
How much did it run you if you don't mind me asking? And does RRE have it on their website?
Old Sep 4, 2012 | 03:48 PM
ambystom01's Avatar
Schroth sells them, they obviously want to make money. The ASM technology is good on Schroths but a harness without roll over protection is pretty unsafe.
Old Sep 4, 2012 | 04:34 PM
neogeo64's Avatar
I thought most open track days only require a helmet. I guess If your doing more then that a roll cage is needed.
Old Sep 4, 2012 | 04:36 PM
Chaz17's Avatar
Yes. A lot of instructors at those track days will actually tell you that your stock 3 point is safer than a 4 point harness. This is legal, but slightly dangerous too.
Old Sep 4, 2012 | 04:55 PM
ambystom01's Avatar
Pretty much, a safety system is a system, change one component and everything else needs to be re-examined.
Old Sep 4, 2012 | 08:48 PM
sstevojr's Avatar
If what you say is true, then every Schroth harness owner the world over needs to start a class action lawsuit. There instructions specifically state to install this way (with the exception of the tunnel side of lap band, pending correction), and if the
then we surely need to start litigating.
Old Sep 4, 2012 | 08:53 PM
sstevojr's Avatar
Dang, looks like it's a world wide conspiracy:
http://www.schrothracing.com/docs/NH...f_Approval.pdf
Damn Capitalists throwing peoples safety out the window, quick take up your pitch forks.
Old Sep 4, 2012 | 08:57 PM
Chaz17's Avatar
Okay it's not getting through clearly. It is perfectly LEGAL to do certain events and daily driving with it that way, HOWEVER, that does not automatically make it perfectly safe.
Old Sep 4, 2012 | 09:11 PM
sstevojr's Avatar
And there is my issue with the choice of words. Sure, it may not be "optimal" but it is perfectly safe.
