I have a 2011 Mitsubishi Lancer Ralliart and have the COBB acessport v2 and was wondering how to switch maps from performance map to economy map. From my understanding by default it has 2 way map switching and already loaded with the V300 maps. I check the settings with there acessrace tuner and its set up to use the cruse control button. I have held it for 3 and 5 seconds and even held it till the cruse light came on and went off. On the lancer it don't have a inter cooler spray light that comes on the dash. I have tried it in different gears and n and park. Under different loads. I cant seem to notice a difference at all. Thanks
Dont bother unless youre using the 2-way for switching from E85 to 93. Econo doesnt make much of a difference. Your foot is what will make a difference.
To answer your question, check under monitoring (there should be an option to see which map are you using).
Ok great, yeah found it under monitoring. Thanks and yeah eco don't seem like much if any difference. Holding the cruise control button down does change that maps.
