2014 Ralliart Speaker Install??
I purchased a 2014 Ralliart this December and have been looking at upgrading the factory audio system. I have the NON-Navi touchscreen unit that doesn't have the fosgate system or anything special. Does anyone know what size speakers are in there and if the previous years would work with the '14?
Fronts are 6.5 component (can fit up to 1" tweeter in the sail panel).
Research more - you have to get an adapter plate or cut/mod the old speaker to use as an adapter plate for the doors. Mitsu used 3 hole speakers and almost all aftermarket are 4 hole.
You can also get the Alpine 'universal fit' with a swiss-chees frame that you align with the holes that match...
i just replaced the deck and rear speakers. the rears are also 6.5" i reused the oem housings by flipping the speaker over and stomping on the backside of the speaker, comes out easy
then I just drilled out the holes where I needed them and used longer screws. works great and sounds better than the **** oem speakers
dcevox
Apr 17, 2018 02:09 PM
