love it, when I get my ralliart I'm getting the AMS catback, plasti-dipping the nose ring and window trims, then bringing it to AMS and getting it tuned.
Quote:
Wonder how the resanator test pipe sound? 08Lancer89 I keep listening to yours and I'm leaning more and more twords the Single exit. I just want it a little more mellow. Got almost an hour commute to work and I'm getting old.Originally Posted by 08Lancer89
hell yeah it dose it sounds nasty as hell in person
its really not that loud, it has a nice tone to it. when in the car with the music on like 30 you can hear it just slightly over the radio. I like it because it only sounds nasty when you stomp on it and at idel its just a lil bit louder than stock.
Get it dude you will love it. I'm going to get a highflow cat and downpipe next.
.Newbie
Quote:
did it come with rubber hanger? and which one did you chang it to? because i didn't like how it kinda sat low before....Originally Posted by 08Lancer89
here are a few new pics, I changed the rubber hanger and put it the way its sopposed to be sits alot an 1inch higher now looks really good.
The rubber hanger is the one from the passnger side. It's one of the stock hangers. AMS has install instructions on there website. As far as jack placment I just jacked up the whole car on 4 Jackstands as high as I could get it safely. Just make It so u can get under the car good. When takin off the stock muffler I used the jack that's in the trunk along with a two by four to lift up the muffler to relase pressure on the rubber hangers then I sprayed a lil wd40 to get them loose after undoing the two 14 mm I think bolts where the muffler bolts at the axle I lowerd the jack and the muffler was out. As far as the two bolts at the cat those where hardest to get off. So I carefully used an impact gun. Alot the metal heat shield around the flange where the cat is u have to bend out a little because the new ams pipe flange is slightly bigger but other than that it took like 30 min. Hope this helps.
Quote:
Is it as loud as UR that it drones itself out cruzing? Would it be annoying if you were a passenger in the back or baby?Originally Posted by 08Lancer89
no I had my car full the other day its only loud under ft. other than that its not bad at all.
