09+ Ralliart Show and Shine Post your pictures, photoshops, and videos!
Front Nose Vinyl
Old May 21, 2010 | 12:46 PM
PCToolsWiki's Avatar
Any update on if you are going to sell them?
Old May 21, 2010 | 12:59 PM
alienxx45's Avatar
interested as well
Old May 22, 2010 | 08:35 AM
8urSuby's Avatar
nice job!
Old May 23, 2010 | 08:38 AM
Kieffer87's Avatar
I have some bad news guys, this would be next to impossible to apply as a precut sticker. I think it probably could be done but you would have to be so precise and there wouldn't be any room for error. I attempted 3 times to apply a precut piece with no luck, it was always looking great then I would get to the other end and it woud be all wrinkled or too short what a PITA. I worked on those for about 2 hours. Then I just took a sheet and had it all applied and trimmed in less than 20 minutes.
What I have decided to do though is if anyone is interested in getting a sheet of vinyl I will sell a sheet that is roughly close to what you will need, a little bigger for some room to mess up. Once it is on there it's easy to just cut where you need it to. Im still thinking in the neighborhood of around $15-20 shipped if anyone is still interested. I will talk with my business partner tomorrow and run it past him.
Picutres will be posted up later today.
Old May 23, 2010 | 10:11 AM
07outty's Avatar
the secret to applying vinyl to that area under the ring is.........
.......start in the middle ....then work your way to each side.
if you start on one side.. you end up using alot more vinyl than you should.
Old May 23, 2010 | 10:26 AM
How do you cut it? With like an exacto knife? Maybe pictures or videos on where to cut also.
Old May 23, 2010 | 08:05 PM
Kieffer87's Avatar
This is exactly how I did without much luck. I always work with flat surfaces .
Couple Iphone pictures:
Old May 23, 2010 | 08:10 PM
Kieffer87's Avatar
Yea I took the nose ring off, put the vinyl on wetting both the lip and the sticky side of the vinyl. Then once it was where I wanted I used a heat gun (or space heater would work too) and got all the bubbles out with a squeegee. After about 20 minutes of drying I then cut around where the ring goes and then cut straight down on both sides with a flexible ruler and an exacto knife.
Old May 27, 2010 | 09:58 AM
Update?
Old May 28, 2010 | 10:51 PM
GenetiX403's Avatar
damn if i didnt have 3m on my car...
Old May 28, 2010 | 11:36 PM
Cosis's Avatar
same here steve, same here
Old May 28, 2010 | 11:45 PM
GenetiX403's Avatar
use a paint brush hahaha
Old May 29, 2010 | 01:05 PM
Karnage541's Avatar
Anyone have the vinyl on without blacking out the ring? Im just curious on how it will look lol. Prob like crap, but you never know.
Old May 30, 2010 | 12:41 PM
Kieffer87's Avatar
I can't imagine it would look very well.
Old May 30, 2010 | 12:46 PM
Can we vinyl the ring as well? or just Plasti dip?
