Door lock actuator needed
Old Sep 7, 2009 | 06:29 PM
rcheung's Avatar
I need the part number for the drivers side front door lock actuator.
Old Sep 8, 2009 | 08:12 AM
RussellM's Avatar
Plat Vendor
LINK
http://www.mitsubishiparts.net/cart/?id=571&pn=mn159933
Old Mar 3, 2010 | 01:46 PM
thevalleyboy's Avatar
Man those things are not cheap - I need one also - anybody in the Calgary, Alberta area that can hook me up with one? Used maybe or at dealer cost + a little to pad your pocket? Let me know! I guess I might have to see if any of the junk yards have them
Old Mar 4, 2010 | 06:21 AM
RussellM's Avatar
Plat Vendor
We do ship to Canada.
Old Aug 24, 2012 | 06:45 PM
jujuizm's Avatar
my power lock actuator on the front driver's side just broke is this common for the evos?
Old Sep 2, 2012 | 11:34 PM
10isace's Avatar
Mine is broke too. What are your symptoms?
Old Sep 21, 2012 | 02:42 PM
vortico's Avatar
Mine just broke as well, in my case electrically locking or unlocking the doors via remote or button will not unlock or lock my driver side front door. It does appear to try moving however, very slightly.
Old Sep 21, 2012 | 08:20 PM
10isace's Avatar
Mine is exactly the same.
Old Sep 23, 2012 | 12:28 PM
jujuizm's Avatar
Sorry if i took a while to reply. I finally fixed mine without buying one from the dealership. The power lock actuator on the driver's side can be fixed with a little patience. I started to remove my door panel, so i can remove the whole lock assembly which is such a p.i.t.a. to remove since its all connected together with the door latch. LOL.
You will need to open the actuator water tight casing, which you will have access to the little electric motor that turns the gears inside. all i did was i opened that motor and cleaned it with an electric connector spray cleaner, put everything back on together and it works!
as time goes by, that little electric motor builds up carbon because of the magnet that moves inside. and mine was effin dirty! as soon as i got rid of the carbon build up, it finally work.
btw, when puting it back on together, i just used an epoxy glue to seal the actuator casing back together. works fine with me!
its a very tedious job but hey, it saved me about $250 from buying the whole assembly from the dealership.
Old Sep 27, 2012 | 07:06 PM
10isace's Avatar
That sounds AWESOME!!! Do you have any pics? Is it by the door latch?
Old Oct 8, 2012 | 10:11 AM
rrstlevo's Avatar
Same problem here...I'll attempt to do this sometime this week...I'll snap some pics...hope it fixes my weak little lock actuator .
Old Oct 13, 2012 | 03:10 PM
madmik2657's Avatar
Having the same issue. Any pics you can post would be great! Thanks!
Old Oct 26, 2012 | 02:55 PM
rrstlevo's Avatar
Removed da styrofoam...you'll then have to carefully remove the lock cylinder and handle push rods
BLUE loctite on STUPID phillips head bolts...
Cleaned up contacts and gears, re-lubed all and reassembled in reverse order, duh
End result is: I still need a new lock actuator.
It works better but every now and then doesn't move and I have to use my key to unlock/lock the door. When I put power to the motor in the actuator it would spin then quit...thus a faulty motor so I still need a new lock.
But I figured I would post the few pics I took.
Nick
Old Oct 26, 2012 | 07:41 PM
10isace's Avatar
Thanks for doing that! Took one for the team, yet no payoff! I was so hopeful too. I was thinking I'd just order new after I got to the part where you cleaned the contacts. Then I read it didn't work. Bummer.
Old Oct 28, 2012 | 02:04 PM
jujuizm's Avatar
That electric motor that says "made in Vietnam" that's the one that u need to open up too. You missed that step.. there is a carbon build up in there because of the magnet that moves in there. You can use an electric aerosol spray cleaner or even a brake cleaner once u open that mechanism up. I used 2 small screw drivers to pry that thing open. I'll try to post up some pix. I do have an extra electric motor that I pulled out from an eclipse thinking it would be the same size. The motor is the same size but the gear on the eclipse actuator is a fixed metal gear, not a plastic removable gear just like on an evo, and the diameter of the gear on the little electric motor on the eclipse is a lot smaller. That's why I was forced to pry open and clean that little electric motor that broke on the evo.
