Detailed mapping of Periphery bits underway
has any1 noticed that when you disable FCA bit. 13, 14, 15, in ecuflash (IX Rom 88590715)
it changes periphery 2hex from EDDF, to 0DDF. Is this normal? I have disabled all the bits manually. I tried using 0x0001 (once al of the other bits were disabled manually, besides 13,14,15), and it disabled bits. 13, 14, and 15, and 11,10,8,7,6,4,3,2,1,0.
So my question is, should I leave it as 0DDF, or should I set it as 0001, and change the rest of the bits back, or leave the rest of the bits disabled?
as fixem said re-enable FAA bit. 11 That jacks up cold start.
While searching for a resolution to the P0622 code thrown when using an Evo ECU in a 1G I saw it mentioned that this code could possibly be connected to FDA bit.13.
Has anyone examined this bit?
I've been searching and cross posting to see if anybody knows what the F9A Periphery Bits do.
I was hoping a disassembler has figured this out. Or somebody tried it on their car and logged results.
I'm thinking of trying it and just do an idle, cruise and part throttle log for each one.
http://evoecu.logic.net/wiki/Periphery_Configuration
i updated the wiki, can you all check, if its all right?
Hi,
Is there a possibility to disables the OBD-II communications by changing the Periphery bit's? I am asking about this because something happened and I am unable to data log via OBD-II using cable 1.3 and 2.0. If yes then which bits should I check.
Thank's for help
Thank's for help
I'm not aware of any way to disable OBD-II communications with the periphery bits, but I have not investigated all of them.
