Injector scaling vs actual afr in close loop? Also does ve change closed loop fueling
Old Feb 6, 2013 | 07:09 PM
  #61
10isace's Avatar
Originally Posted by 211ratsbud
My ltft was .5 and 8 .....low mid but cruising and idling is part of the story.. I did a neutral rev slowly increasing the revs and that's where **** got haywire
Did you set your wot fuel mapping and adjust strictly ve ?
Yes. It's working pretty good. I need to change a few cells in WOT parts of the fuel map, but overall it's pretty close.
However, my CL is driving me nuts. I'm changing my plugs now and lowered my latencies another 5% to see if that helps.
Old Feb 6, 2013 | 09:42 PM
  #62
211Ratsbud's Avatar
I get random afr swings in cl. Like stft will be near zero at 75 ve at 2000 but swing to 62 ve by 2250.. See any oddities like that?
Old Feb 7, 2013 | 10:54 AM
  #63
10isace's Avatar
I haven't paid that close attention to that. I do notice at idle that the VE sometimes goes down as the KPA goes up if my idle is fluctuating.
I also notice that the KPA goes down in neutral while revving to get the RPM VE per Schiedes instructions.
Old Feb 8, 2013 | 03:00 PM
  #64
10isace's Avatar
I got my Maf back on the car. I'll do some logging tomorrow as I'm headed to a meeting in Denver right now.
OT, I tried switching to 94171715 SD Rom before I went to the Maf and it wouldn't idle. It was around 21 AFR. I plugged in the MAF sensor and bam, it ran just fine. I'm assuming I did something wrong in the XML files and I really wasn't on an SD Rom. Can anyone clue me in? I was rushing too. I thought I knew this inside and out.
Old Feb 8, 2013 | 04:24 PM
  #65
211Ratsbud's Avatar
I'm not sure if this is the case or not but there are probably some significant maf scaling differences did you look into that?
Old Feb 8, 2013 | 08:32 PM
  #66
10isace's Avatar
Thanks, I'll check that out. I also think I need to rename the Tephra XML to 94171715 in the ecuflash rommetadata folder.
Old Feb 9, 2013 | 07:37 AM
  #67
211Ratsbud's Avatar
Oh you're using 2d? I thought you were 3d this whole time lol
Old Feb 9, 2013 | 08:13 AM
  #68
10isace's Avatar
Haha! I should have mentioned that since I knew you're on 3d. I may try 3d after I get the 94171715 working. I think the 3d will make more sense to me.
About to test the VE on Maf. I'm just curious what Jamie does with these numbers. I will try to make sense of it.
Old Feb 9, 2013 | 08:27 AM
  #69
Dynotech Tuning's Avatar
What map sensor are you using and what is the KPA formula you are using in evoscan? The biggest problem I have seen is improper KPA formulas bein used by some, which obviously throws off the data.
If you are using the LIVE map tracer on evoscan, you can see the average VE values occur while you drive. There are 2 things to remember though:
-The maps are using your LOAD as the top axis, not KPA so it's not a simple way to just swap over the info.
-If you decelerate with the throttle closed, compensations really will skew the numbers so try to log each area while at part throttle in the cruising areas.
Here is a tip, rename your MAP sensor KPA in evoscan so the 'Log Reference' has the word "LOAD" in it. Then you can select our KPA values in the LIVE Map Tracer as a LOAD option. For instance, change the Log Reference from something like 'JDMmapKPA' to 'JDMmapKPA_LOAD'. Close evoscan and then re-open and try it.
Evoscan already offers instances where it only logs data over a specified TPS (like 80%). It would be cool if anyone knew how we could add the option to have it ignore data BELOW a certain TPS while logging so it ignored the decel VE anomalies.
It would also be great if the next version of evoscan could allow us to select the VE table and allow us to choose KPA loggable items instead of LOAD.
-Jamie
Old Feb 9, 2013 | 08:51 AM
  #70
10isace's Avatar
^ Got it. This makes sense for 3d tables. At least I'll have the data. So I assume for the 3d version I should try to get as much resolution as possible. For example, drive in 2500 in as many VE and Load cells as possible, then move on to the next RPM cell and repeat.
I'm using the Omni 4 bar and using 1.6667*x for the KPA settings.
Old Feb 9, 2013 | 11:37 AM
  #71
211Ratsbud's Avatar
For that reason I'm using a elm/DMA rom waiting on a1.3 cable..
But I'm not sure if it would help the maf side of things
So I have yet to use it, but Im hoping that it helps tune things in nicely.
I have to make a decision to jump back to a USDM rom or not. 8858 vs 8859, the usdm is way more supported, but the 8858 has the SAS that I have been tinkering with. hopefully the ISCV stuff and the advanced fuel options get dug up for the 8858 that would pretty much make it equal.
Old Feb 9, 2013 | 01:42 PM
  #72
10isace's Avatar
Lucky! Is there a DMA 94171715 Rom?
After logging it looks like I can plug in the VE settings versus the KPA settings in a 3d ve table. I think I'll try that tonight after I try the 2d sd rom with this info.
Old Feb 9, 2013 | 01:58 PM
  #73
211Ratsbud's Avatar
I think there is a patch program that does it for you, you would have to experiment with that yourself, as Donner was looking for me to test his 8858 rom out because... infact he had to reduce the size of the VE table to fit it in the live map settings. Works out good though. if you check his website, Im pretty sure theres a livemap/dma version there might be 9653 though.. Ill look for it in a bit
youre almost just as good off logging the heck of your maf map thats fully tuned and put that VE into a 3d rom. I was so sure thats what you were doing the whole time too! lol
Old Feb 9, 2013 | 02:20 PM
  #74
10isace's Avatar
I'll be doing all that for sure! In my mind it makes life easier.
However, I'm stubborn and I have to get 2d working perfectly. If one tuner can do it, I can do it. It's more like a handful of tuners can do it. What's wrong with me?
Old Feb 9, 2013 | 02:29 PM
  #75
NOTE***updated OMNI 4 bar KPA after correcting math error*** 2/10/2013
Here are the formula's I use if anyone wants to try them. I also renamed them so you can choose them as a LOAD option on the LIVE MAp Tracer screen in evoscan:
JDM MAP KPA
Code:
<DataListItem DataLog="N" Color="" Display="JDM MAP kpa" LogReference="JDMMAPkpa_load" RequestID="38" Eval="0.19347*x*6.89475729" Unit="kpa" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="350" ChartMin="0" ChartMax="350" ScalingFactor="1" Notes="" Priority="1" Visible="False" LogHide="false" />
OMNI 4 BAR MAP KPA
Code:
<DataListItem DataLog="N" Color="" Display="OMNI 4 bar kPA" LogReference="OMNI4barKPA_load" RequestID="38" Eval="(x/255+0.00842)/0.002421" Unit="kpa" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="400" ChartMin="0" ChartMax="400" ScalingFactor="1" Notes="" Priority="1" Visible="False" LogHide="false" />
AEM or Zeitronix 5bar MAP KPA
Code:
<DataListItem DataLog="N" Color="" Display="AEM 5 bar kPa" LogReference="AEM5barKPA_load" RequestID="38" Eval="(x*0.367647-9.375)*6.89475729" Unit="kPa" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="500" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes="" Priority="1" PriorityOffset="0" LogHide="false" Visible="False" />
Here are the VE formulas:
JDM MAP VE
Code:
<DataListItem DataLog="N" Color="" Display="VE JDM 3 Bar" LogReference="VE_JDM3bar" RequestID="00" Eval="([load1B]/[JDMMAPkpa])*100" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" PriorityOffset="0" LogHide="false" Visible="False" />
OMNI 4 Bar MAP VE
Code:
<DataListItem DataLog="N" Color="" Display="VE Omni 4 Bar" LogReference="VE_OMNI4bar" RequestID="00" Eval="([load1B]/[OMNI4barKPA_load])*100" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="150" ChartMin="0" ChartMax="150" ScalingFactor="1" Notes="" Priority="1" PriorityOffset="0" LogHide="false" Visible="False" />
AEM or Zeitronix 5 bar VE
Code:
<DataListItem DataLog="N" Color="" Display="VE AEM 5 bar" LogReference="VE_AEM_5_bar" RequestID="x" Eval="([load1B]/[AEM5barKPA_load])*100" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="130" ChartMin="0" ChartMax="130" ScalingFactor="2" Notes="" Priority="1" PriorityOffset="0" LogHide="false" Visible="False" />
-Jamie
