Injector scaling vs actual afr in close loop? Also does ve change closed loop fueling
-Jamie
3 years Ive been at this approach. I have concepts down, its down to figuring out why 1 degree difference at 200 load and 220 load can make a difference.
0.2369*x*6.89475729 = 1.6333
Jamie,
I see my eval is different than yours. Is mine pretty far off? I did a lot of logging today and am setting up my 3d SD Rom. I'd like to plug in the numbers tonight, but I could wait until tomorrow with your eval.
***UPDATED 2/10/2013 with corrected formulas***
I'm glad you asked! After doing some digging, here are the ACTUAL formulas for the OMNI 3, 4 & 7 bar sensors from OMNI's actual formulas.
http://omnipowerusa.com/calibrations.doc
OMNI 3 bar kpa= x*1.23755087
OMNI 4 bar kpa= x*1.63345239
OMNI 7 bar kpa= (x/255-0.04)/0.0012858
OMNI 3 BAR MAP KPA
OMNI 4 BAR MAP KPA
OMNI 7 BAR MAP KPA
-Jamie
OMNI 3 BAR MAP KPA
Code:
<DataListItem DataLog="N" Color="" Display="OMNI 3 bar kPA" LogReference="OMNI3barKPA_load" RequestID="38" Eval="x*1.23755087" Unit="kpa" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="1" Visible="False" LogHide="false" />
OMNI 4 BAR MAP KPA
Code:
<DataListItem DataLog="N" Color="" Display="OMNI 4 bar kPA" LogReference="OMNI4barKPA_load" RequestID="38" Eval="x*1.63345239" Unit="kpa" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="400" ChartMin="0" ChartMax="400" ScalingFactor="1" Notes="" Priority="1" Visible="False" LogHide="false" />
Code:
<DataListItem DataLog="N" Color="" Display="OMNI 7 bar kPA" LogReference="OMNI7barKPA_load" RequestID="38" Eval="(x/255-0.04)/0.0012858" Unit="kpa" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="700" ChartMin="0" ChartMax="700" ScalingFactor="1" Notes="" Priority="1" Visible="False" LogHide="false" />
-Jamie
Did you mean x*x*1.63345239 or x*1.63345239 for the 4 bar. I bet I'd get some interesting numbers with x*x*1.63345239.
Wow, this is an effort to get this right and smoothed. I haven't even flashed this in my car yet.
I can see how decel can throw the numbers off. I tried to eliminate that via Excel by deleting those cells and obvious high VE numbers to get averages.
This is my first go at it. It took hours to do. I'm doing my second log to see if it matches up. I'll do more logging tomorrow.
I assume I smooth these out.
It took you hours to do that? Send me that datalog and I will take a look the way I generally do it and see if I can show you how to do it in minutes. Use the email in my signature.
-Jamie
-Jamie
I know right. I got on a roll doing it my way, but after about 5 minutes of filtering and formula's in Excel to do one cell on the 3d map... I decided to keep doing it my way.
Bad decision.I looked at EvoScan graph and thought the info was being thrown off by decel, so I went into Excel to clean it up and never came out of Excel. I was trapped.
If you just log ve and kpa can you not just enter the ve by what it read at that kpa?
I still don't comprehend how to get around the difference in load to kpa on a maf to sd rom. My load reads higher on sd per boost level than on maf.
So are we using the right kpa formula then 10isace?
Ya know I looked at your handle for a while and said ten-ac-ious
Ten is ace. Comprehension > me
