Were to get cruise control??
Old Mar 23, 2005 | 06:47 AM
oak2207's Avatar
Originally Posted by Cajun Power
I don't see mitsu putting cruise on any EVO's. Too many problems to get the car to hold speed up a hill and not spazz out when it tops the hill and buck trying to let off and coast. I think it would just be a ***** in the armor (no pun intended).
That's usually my response when people ask me why I don't have it... "Then how does the STi do it?" is the response back. Anyone?
Old Mar 23, 2005 | 06:50 AM
osunick's Avatar
Like I said, there are no technical limitations to putting a cruise control on a manual equipped car. The car can't shift but usually you have enough torque to hold speed up hills and you car is not going to buck when you're at 3000 rpm anyway. I have never experienced bucking when using cruise on my evo.
The STi has a electronic throttle so the cruise is basically software. But like I said before the reasons for no cruise is that no one has historically wanted it, not any technical reason.
Old Mar 23, 2005 | 07:05 AM
oak2207's Avatar
I can see how it would have trouble with the turbo lag and such, how it could overshoot it's desired speed, but there's so many turbo cars out there with cruise. Is the drive-by-wire the key?
Old Mar 23, 2005 | 07:08 AM
osunick's Avatar
NO. As I've said twice, it works fine on my evo. There is zero problem other than mitsubishi chose not to offer it. That's it. It MIGHT be a problem if you're setting your cruise at 60 mph while in third gear, but most cruise controls won't let you set cruise past a certain rpm.
Cruise control algorithms are very sophisticated now. Basically they use calculus to map acceleration to speed and rarely do they overshoot. The cruise control on my car works as good as any factory system, there's enough engine braking that once you reach the desired speed, lifting the throttle will hold that speed without overshooting.
In europe and japan, not many people use cruise. That's where the evo's been sold until 2003 and the volumes in the US probably don't justify adding cruise. It's a pain to add from a logistics standpoint, where minimizing market to market variation is the goal, and honestly, who's not buying an evo because it doesn't have cruise?
Drive by wire makes it easier to implement cruise since all the hardware is already there, having a throttle cable complicates the implementation of cruise but there is no technical reason why it won't work on an evo. In the end, making the changes to the car probably didn't justify the cost to mitsubishi.
Old Mar 23, 2005 | 07:31 AM
Zeus's Avatar
That is the only feature that I direly miss on the Evo! It is my daily driver. The STI was just too "soft" a car compared to the Evo, so I didn't even consider it for long.
Old Mar 23, 2005 | 10:41 AM
nabit's Avatar
Thanks alot for all the help..I will check around here and see if anyone can add cruise to his car...Thanks again for responding!!!!
Old Apr 9, 2005 | 07:27 PM
WarmPepsi's Avatar
it works fine, not real happy with the way they want the line secured around the throttle loop though.
For $200? yeah, it's worth it.
Old May 18, 2005 | 03:08 AM
Addicted4Life's Avatar
Mine works perfectly over hills actually. Being in overdrive makes it hard to spazz out.
The previous owner of my car had cruise control installed. I don't know what type it is. It has a vacuum line going to it that has been spliced into the brake booster line. It works ok, but it will not build boost. The throttle will move quickly but only to "0" on the boost gauge. It's pretty much worthless up most hills because a few psi is needed in 5th gear to keep the car at a constant speed. I wonder if I using a different vacuum source would help. Maybe the cruise unit isn't made to see boost so it freeks out? Anybody know about these things?
Old May 18, 2005 | 03:40 AM
WarmPepsi's Avatar
you need an electric setup for a boosted application. mine works just fine.
was key in a 3k mile road trip 2 weeks ago.
Old May 18, 2005 | 04:01 AM
wheming's Avatar
Install a check valve in the line so that the cruise actuator only sees vacuum. AND also add a vacuum resovoir on the "only vacuum" side. This will give you a vacuum reserve so when your in cruise and climbing a hill you'll still have vacuum to move the actuator more. this will allow you to actually go into boost while using cruise.
Works great in my Dodge.
Or
you could try using a turbo inlet vacuum source. I don't know what kind of vacuum you'd get, especially with a free flowing turbo intake.
Some cars come with vacuum resovoirs. Those early Ford Exploders had one, just look around a junkyard. Mine is a 1 QT Nalgene vacuum bottle.
Old May 18, 2005 | 04:11 AM
wheming's Avatar
I didn't see where you said what manufacturer is yours?
Could you post some pics of the controls and the underhood?
I'm going to be taking a trip to FL in July and want to take the Evo, but I think I'll need some cruise for that. Otherwise I might have to let someone else drive a while....and that ain't gonna happen...
Old May 18, 2005 | 04:20 AM
WarmPepsi's Avatar
haha, you grabbed me in that willing few minutes before work
rostra, they're oem for gm and a few others, i'd give it an 8-10, on resuming on hills, it hunts a little but again on big hills, you're normally having fun with the evo
Overall, i'd get it again.
and an idiots guide...
Old May 18, 2005 | 07:51 AM
chrisw's Avatar
oh never mind...
Old May 18, 2005 | 08:09 AM
wheming's Avatar
jeesh, that control box looks bigger on your car than on their website.
It fit in that spot without too much trouble, and without eliminating something else?
thanks for the pics!
Old May 18, 2005 | 08:34 AM
HuskerEVO's Avatar
There are some other threads about cruise control... here is one that has useful information: https://www.evolutionm.net/forums/sh...cruise+control
