Automotosports - Illinois Automotosports is a Chicago based tuner specializing in 4G63T performance. With an in-house fabrication facility and engineers on staff, they will be bringing you the best in Lancer Evolution parts.
AMS LICP Install problems
Old Oct 11, 2005 | 03:08 PM
Iceman2011's Avatar
i got it on T-clamps for about 4 days now nothing yet, havent been driving hard on it though.
Old Oct 11, 2005 | 03:30 PM
construct1's Avatar
did not mention though that I installed an ams front mount on and two days later is when the lower pipe blew off, (put on a couple weeks before the fmic) so I could have wiggeled it loose installing the front mount, from what I've been told the clamp should go on right after the ring which is about an inch or inch1/2 from the rolled end, then it should not come off and has not happened since, clamp is as tight as it's going to get, so time will tell!
Old Oct 11, 2005 | 03:34 PM
warp9's Avatar
AMS, i didnt know you guys had aluminum pipes. You guys are the exception.
Old Oct 11, 2005 | 03:37 PM
GreddyEvo's Avatar
The pipes are awesome, they weigh almost nothing!
Old Oct 11, 2005 | 04:18 PM
warp9's Avatar
Aluminum is good!
Old Oct 11, 2005 | 04:25 PM
JoeWalker4G63's Avatar
What the guy is saying is that the AMS LICP does not have braces that bolt to the car. This is my only complaint about the product. I am going to wrap a section of my pipe with a peice of rubber and use some zip ties to help pull the pipe up and make it more secure.
Old Oct 11, 2005 | 06:07 PM
MYEVOVIII's Avatar
I used the AMS clamps that came with the kit when I installed the LICP on my friends Evo and he has had no problems. Unless you count full boost 200-300 rpms sooner and 8whp and18 fts of tq he gained on the dyno.
Maxtor
Dec 19, 2013 03:37 PM
HR2L
Mitsubishi TC-SST Discussion
Jul 29, 2010 12:21 PM
Dre1189
20
Feb 19, 2010 10:28 AM
EvolNinja
55
Jan 10, 2009 10:27 AM
A.J.'s_EVO
15
Nov 3, 2008 04:32 PM
