Vendor Service / Parts / Tuning Review Post your service, part & tuning reviews here. Please note all new threads are moderated.
Dyno Graphs and LM-1 Screen Shots
Old Jan 13, 2006 | 12:43 AM
KevOVIII's Avatar
I would first like to thank the SF Bay Area Dyno Testing team for Thursday's dyno runs. Thank you Jerry and Sean(?) at Full Function. Thank you Mike, Tommy, and Tom at Gruppe-S. The guys at each place were really nice and professional throughout.
I will thank Shiv at Vishnu when I dyno there on Friday.
https://www.evolutionm.net/forums/sh...d.php?t=178048
https://www.evolutionm.net/forums/sh...d.php?t=178067
List of mods on the car
- K&N drop-in panel filter
- Blitz SBC-iD boost controller
- APS blow off valve
- Buschur turbo-back
- HKS 272/272 cams
- Fidanza cam gears set at -4i/-1.5e
- Revolver valve springs and retainers
- APR head studs
- Nisei intercooler and intercooler piping
- Helix 720cc injectors
- Perrin fuel rail
- Walbro 255 lph fuel pump
- HKS DLI-II twin power ignition
- SMC alky kit with M7 nozzle
- S-AFC II
- NGK BPR8ES gapped to 0.025"
- DynoFlash custom road tune
- Innovate LM-1 and XD-1 for monitoring
The boost controller was set to 74 (about 23 psi) and gain to 14.
S-AFC II was zeroed out.
The SMC alky kit was set to start at 18 psi and max out at 28 psi.
These settings are what Al left them at on December 17th, 2005 at the end of my custom road tune.
LM-1 screen shots:
Purple is air/fuel ratio
Black is RPM
Red is throttle position in volts
Green is knock in volts
Blue is intake air temperature in degrees Fahrenheit
Orange is boost in PSI
Old Jan 13, 2006 | 12:48 AM
KevOVIII's Avatar
Dyno at Full Function
Dynos in 4th gear
#1 run: The dyno operator had the parking brake (e-brake) partially up by accident, so the numbers are scewed a bit. You can see the knock throughout the RPM band. We joked about the mistake. Good thing the diff disengages with the hand brake up.
Attached Thumbnails Dyno Graphs and LM-1 Screen Shots-060112_1b_s_full_function.jpg   Dyno Graphs and LM-1 Screen Shots-060112_full_function_1.gif   Dyno Graphs and LM-1 Screen Shots-060112_full_function_2.gif   Dyno Graphs and LM-1 Screen Shots-060112_full_function_3.gif
Old Jan 13, 2006 | 12:55 AM
KevOVIII's Avatar
Dyno at Gruppe-S
3rd gear runs
Attached Thumbnails Dyno Graphs and LM-1 Screen Shots-060112_1a_s_gruppe-s.jpg   Dyno Graphs and LM-1 Screen Shots-060112_1b_s_gruppe-s.jpg   Dyno Graphs and LM-1 Screen Shots-060112_gruppe-s_4.gif   Dyno Graphs and LM-1 Screen Shots-060112_2a_s_gruppe-s.jpg   Dyno Graphs and LM-1 Screen Shots-060112_gruppe-s_5.gif
Old Jan 13, 2006 | 01:03 AM
KevOVIII's Avatar
I asked Mike if it was okay to turn up the boost to 25 psi, change the SMC alky controller to start at 11 psi and max at 18 psi. The S-AFC was altered with the settings I road tuned this past Saturday.
Al had recommended against doing this when I asked him about it because he said my car was plenty fast and pulled hard. I wasn't satisfied, so the result is this.
Attached Thumbnails Dyno Graphs and LM-1 Screen Shots-060112_3a_s_gruppe-s.jpg   Dyno Graphs and LM-1 Screen Shots-060112_gruppe-s_6.gif   Dyno Graphs and LM-1 Screen Shots-060112_4a_s_gruppe-s.jpg   Dyno Graphs and LM-1 Screen Shots-060112_gruppe-s_7.gif
Old Jan 13, 2006 | 01:06 AM
KevOVIII's Avatar
This was another pull to verify the hp and tq
Unfortunately, the LM-1 didn't log this pull.
Attached Thumbnails Dyno Graphs and LM-1 Screen Shots-060112_5a_s_gruppe-s.jpg
Old Jan 13, 2006 | 01:12 AM
KevOVIII's Avatar
Mike decided to try and do an apples-to-apples comparison, so he asked me to return the settings (boost, S-AFC, SMC) back to what they were so he can make a couple 4th gear pulls.
Attached Thumbnails Dyno Graphs and LM-1 Screen Shots-060112_6a_s_gruppe-s.jpg   Dyno Graphs and LM-1 Screen Shots-060112_6b_s_gruppe-s.jpg   Dyno Graphs and LM-1 Screen Shots-060112_gruppe-s_9.gif   Dyno Graphs and LM-1 Screen Shots-060112_7a_s_gruppe-s.jpg   Dyno Graphs and LM-1 Screen Shots-060112_7b_s_gruppe-s.jpg
Old Jan 13, 2006 | 01:15 AM
KevOVIII's Avatar
To verify the previous run.
Attached Thumbnails Dyno Graphs and LM-1 Screen Shots-060112_gruppe-s_10.gif
Old Jan 13, 2006 | 01:21 AM
KevOVIII's Avatar
I assume it's okay to post the LM-1 log files from the DynoFlash custom road tune from December 17th, 2005, but Al has not provided me the info to view them correctly (or even screenshots of the 8 pulls if he doesn't want to disclose the information).
I've asked him in threads (which he locked)
https://www.evolutionm.net/forums/sh...d.php?t=177674
https://www.evolutionm.net/forums/sh...d.php?t=178024
and I've asked him numerous times via PM. I provided screen shots of the log files to Al so he can see that the graphs do not make sense without the needed information. He even said he would provide me the information on Thursday night, but I didn't see a PM and it's Friday.
Thanks for not posting in the thread while I was creating it. You may post your comments/questions/concerns now. Thank you.
Old Jan 13, 2006 | 09:48 AM
DynoFlash's Avatar
Its interesting to note how close the advent of knock threshold is that when the parking break is lifted during the dyno run the car starts with some significant knocking even with the alcohol
This is why i suggested the lower boost on your car
IMHO the power numbers are good for 23 psi of boost and the dyno charts are fairly consistant from shop to shop
Of course its your call to raise up the boost as you have in one pass and make more power.
I have to make recomendations based upon keeping a customer's motor in one piece over a long life span
I did not feel that your car would be happy on the 91 octane with more boost
Glad to see its making more power with more boost
Old Jan 13, 2006 | 09:50 AM
DynoFlash's Avatar
As we have discussed at length, I was confused as to what it is that you wanted as the data was provided to you to review with your log works softwear.
Last night I emailed you the screen shot from how I set up my log works screens as well.
here is what the final log looks like as I set it up
Old Jan 13, 2006 | 10:06 AM
David Buschur's Avatar
Hmm,
I must be lost too. I am assuming the point of this is to praise Al's tuning as the charts from his tune all are very smooth and making 300+ whp on a Mustang Dyno (if set up like ours) on a stock turbo is something to brag about for sure.
The AFR's are rich, as they should be with the Alky on, and the boost looks pretty nice and flat.
The car made more power with more boost and some fine tuning with the AFC. That would make sense too.
David Buschur
www.buschurracing.com
Old Jan 13, 2006 | 10:20 AM
KevOVIII's Avatar
Please note that with an increase in boost and changes to the SMC controller, knock voltage is still lower than some of the other runs.
25 psi peak with my SMC settings and S-AFC tune:
https://www.evolutionm.net/forums/at...id=82084&stc=1
Knock voltage peaks at 0.85V at 7210 RPM
First run at Gruppe-S
https://www.evolutionm.net/forums/at...id=82078&stc=1
Knock voltage spikes at
1.42V at 4710 RPM
1.32V at 6300 RPM
Second run at Gruppe-S
https://www.evolutionm.net/forums/at...id=82080&stc=1
Knock voltage spikes to
1.33V at 6270 RPM
1.13V at 6630 RPM
1.10V at 6850 RPM
Third run at Gruppe-S
https://www.evolutionm.net/forums/at...id=82082&stc=1
Knock voltage peaks at .92V at 7180 RPM
Sixth run at Gruppe-S in 4th gear
https://www.evolutionm.net/forums/at...id=82092&stc=1
1.11V at 5980 RPM
0.91 at a couple other places
Seventh run at Gruppe-S in 4th gear
https://www.evolutionm.net/forums/at...id=82096&stc=1
Knock voltage spike at 1.53V at 7200 RPM
I'm not questioning your tuning skills, but why is my tweak with more boost less knock prone that yours?
Old Jan 13, 2006 | 10:25 AM
RazorLab's Avatar
Since not everyone is familar with the gruppe-s dyno dyno. Yes it does read low, and getting over 300 on it with the stock turbo is hard.
Here is another dyno sheet from that very same dyno for comparison.
No alky, self tuned, stock air filter. All mods in my sig.
Test run is 100 octane, base is 91 octane, no alky
Old Jan 13, 2006 | 10:26 AM
KevOVIII's Avatar
https://www.evolutionm.net/forums/at...chmentid=82104
Here are the instructions I provided you for all to see (via PM). I don't know how it's hard to follow.
Originally Posted by Me
The issue here is that I have the log file but with my configurations (Configure Channel in LogWorks), I see garbage other than AFR and RPM. I just took two screen shots, one is what I see when I view your tune log file (that's because the configuration isn't correct), and two is what I log and see with my configurations.
My questions are
1) I need to know the order in which you have your channels (lines) layed out. From this graph you posted https://www.evolutionm.net/forums/at...chmentid=81813 , it looks like Channel 1 is AFR, Channel 2 is RPM, Channel 3 is throttle position, Channel 4 is knock, Channel 5 is psi, Channel 6 is G's.
2) I need to know what each channel converts to in voltage. Here is an example of what I have (to view, you go to Channels tab -> Configure Channel option -> then the channel itself)
=== throttle position is -0.78 volts to 5.00 volts equivalent to 0V to 5V
=== knock is 0.00 volts to 5.00 volts equivalent to 0V to 5V
=== air intake temperature is 271.5 degF to -58.0 degF equivalent to 0V to 5V
=== boost (with AEM 3.5 bar map sensor) is -20.9 psi to 41.5 psi equivalent to 0V to 5V
Now that you've seen what I have, can you look at your channel configuration and let me know what your values are? Without them, the road tune log isn't too useful because my LogWorks values don't match yours.
Thanks,
Kevin
Please let me know if you need me to create a tutorial for you with step-by-step screen shots so I can finally get the information. Please keep in mind that I told you I will not provide this information to anyone else, but I don't see how the scaling and voltage conversion are trade secrets.
Old Jan 13, 2006 | 10:32 AM
KevOVIII's Avatar
Hmm,
David Buschur
I am neither bashing nor praising Al. All I'm doing is posting the findings for yesterday, and since the sessions were from independant dynos no one can claim that they are biased.
It was a cold and rainy day when Al did the custom tune, so AFR might have changed because it was warmer today.
