Speed bleeders for the Brembos?
Old Sep 3, 2003, 10:37 AM
tom@kartboy's Avatar
does anyone know the part numbers for the brembo brakes? i'm planning on doing the lines fluid and some speedbleeders at the same time.
thanks
Tom
Old Sep 3, 2003, 10:55 AM
IzenGreyEvo7's Avatar
Tom,
I spoke with a few people at Brembo and I thought it was the same caliper as the Track Package Z and Sti. Turns out it's unique to the EVO. Brembo does not sell this caliper over the counter. It's a pure OEM deal.
P.S. The shift knob rocks man, enjoying it much!
Old Sep 3, 2003, 11:01 AM
hmmmm i guess thats going to make it a little harder to figure out...
glad you like the knobber. we should have a true EVO run finished soon. then i have to get the vendor status
Tom
Old Sep 3, 2003, 11:03 AM
Have you tried the brake bleeder from Griot's garage? It pretty much eliminates the need for speed bleeders and it's a lot cleaner too.
Old Sep 3, 2003, 11:54 AM
i have something close but after reading what they say here i'll try the speedbleeders
http://forums.nasioc.com/forums/show...hreadid=415728
tom
Old Sep 3, 2003, 12:14 PM
I don't see where they talk about speed bleeders? The ABS system in this car does not have the hidden passages stoptech refers to.
Old Sep 3, 2003, 03:05 PM
n00dle's Avatar
Speedbleeders are the bomb. Please post numbers if they have them. This would also be good for the clutch slave for those changing out the lines.
Old Sep 4, 2003, 03:42 PM
freedom's Avatar
Re: Speed bleeders for the Brembos?
thanks
Tom
For the front the part number is,
V7-4046
And the rear the part number is,
V6-X40
Old Sep 4, 2003, 04:54 PM
many thanks
now you wouldnt happen to know the clutch slave number?
Tom
Old Sep 4, 2003, 05:09 PM
freedom's Avatar
many thanks
Tom
That information isn't in the shop manual.
Buy a bleeder screw from Mitsubishi?
Old Oct 5, 2003, 10:22 AM
n00dle's Avatar
Tom,
Any luck getting Speedbleeders?
Old Jan 19, 2004, 10:41 PM
Satori's Avatar
FWIW; I emailed www.speedbleeder.com telling them year make and model Evo and that the hex size of the stock bleeders is 11mm front and back. They said the part I need is definitely SB1010S.
I went ahead and ordered them with a little skepticism . I'll keep you posted on how they fit once I get them.
Old Jan 19, 2004, 10:52 PM
Zeus's Avatar
I planned to do the same when I do the lines...
Old Jan 20, 2004, 07:46 AM
amigoni's Avatar
From what it looks like. We need 4 for the front and 4 for the back! Right?
Old Jan 20, 2004, 07:33 PM
n00dle's Avatar
Speedbleeders are available in the Help section at Napa and Kragen Autoparts (Chucks Auto in some areas) Part #12706. Clutch slave is #12709.
Quick Reply: Speed bleeders for the Brembos?
