Why should anyone upgrade turbos?
Old Apr 6, 2006 | 07:02 PM
Ludikraut's Avatar
Originally Posted by blkAMSevo8
no meth, ha no link either, 33-34 psi on pump with a fully built engine.
What octane rating is your pump gas?
l8r)
Old Apr 6, 2006 | 07:15 PM
nrcooled's Avatar
Originally Posted by Ludikraut
Ultimately I think the answer largely depends on the application and platform. For a pump-gas application:
- '03/'04/'05 on a stock block would probably want to go with an Evo IX turbo or TME
- '06 no upgrade really needed
However, in my case, I chose to upgrade (bigger turbo and built block) because I wanted to be able to rev my engine higher and I also wanted better power up top. Ultimately my goal is to have a car that has an ~8500 rpm shift point with a 9000+ rpm redline. Not something the stock turbo or block could ever accomodate. In my case I also found that even the 3071 on pump gas runs out of steam too soon, which is why I'm looking at the 50 trim or 3076. The factory turbos are fairly well matched to the stock engine, and the IX turbo looks like it is outstanding. I would guess that the IX turbo will be the equivalent of a 3071 on pump gas, given the stock redline: maybe a hair less power, but far better spool.
l8r)
I will be keeping my stroker below 7500RPM so a topend monster won't do me any good. I think the 50 trim will be a good trade-off for me. I was looking at the new 20G-9-5 but I think I will let a few folks be the guinea pigs first before I take the dive.
The biggest limiter that I see running a big turbo on pump is "effective" compression ratio. i.e. the more air pumped by the turbo the higher the cylinder pressure = more prone to knock on pump. I am just really stuck on what I can run on a DD and still get good performance for the track.
Luda - thanks for all the input. What were your exact impressions of the 3071? This was one of the turbos that I was looking at along with the 3065 and 50 trim.
Old Apr 6, 2006 | 07:42 PM
C6C6CH3vo's Avatar
The extra 300cc of displacement may provide a little more sub-boost torque while in lag. Shouldn't it also shorten lag duration as well? I'd guess so.
You should ask some other 2.3 users for input
Old Apr 6, 2006 | 09:58 PM
3240's Avatar
I made about 480 whp on 91 octane running a 2.3L with an HKS 3240 turbo. It was done on a dynojet so the numbers might be inflated but it sure did feel fast.
Old Apr 7, 2006 | 07:16 AM
nrcooled's Avatar
Do you have any dyno sheets?
Old Apr 7, 2006 | 07:51 AM
Ted B's Avatar
Then consider a turbo that reaches its practical choke limit around 7500rpm and 25psi for a 2.3L engine and call it a day. That will give you the best compromise between the largest usable powerband and best usable power.
For a 2.3L engine running at 90% VE at 7500rpm, you would be looking at something that will top out around 50lb/min airflow running upward of 25psi. If we look at compressor maps, we find that a GT3076R seems to be ideal for you:
http://www.atpturbo.com/root/maps/gt30r.htm
Old Apr 7, 2006 | 08:07 AM
Warrtalon's Avatar
33-34psi on pump gas/no meth on a GT35r and putting down 600whp? Come on, we know better...
Old Apr 7, 2006 | 08:27 AM
nrcooled's Avatar
i was thinking the same thing. The cylinder pressures would be astronomical at that boost and, theoretically, be knocking all over the place. Unless, of course, the built engine that he is referring to contains 7.1:1 CR pistions
Old Apr 7, 2006 | 08:29 AM
nrcooled's Avatar
Reading compressor maps has never been my strong-point. I guess it's time to learn.
Old Apr 7, 2006 | 08:38 AM
yellowEVO21's Avatar
93/alky, 112, or c16 doesn't count
Old Apr 7, 2006 | 09:05 AM
Torre from Va.'s Avatar
+1
Old Apr 7, 2006 | 09:20 AM
War Monger's Avatar
It came outa a pump, C116 from a pump hehehe. I have seen some DSM's hit the 500WHP range on straight pump but that is a different story for next time kids.
Straight pump gas? cannot beat a 50Trim turbo. Turbo Trixx just tuned a car with their 50Trim kit that made 450WHP on their dynojet, about 100 more then the stock could do.
Old Apr 7, 2006 | 09:30 AM
MREvo-bin's Avatar
if you have a 2.3L block, you should be okay. my friend's evo hits full boost the same as a stock evo does with his 35R and 2.3 block.
Old Apr 7, 2006 | 10:26 AM
Ludikraut's Avatar
It's very hard for me to give feedback on the 3071, since I strongly suspect that other issues on my car are responsible for it performing sub-par. Right now I'm stuck with a car that spools later than expected and the topend is almost, but not quite where I want it to be. I've spent a fair amount of time discussing turbo options with Martin at AMS and he agrees that the 50 trim or 3076 is probably the better choice over the 3071. IIRC, as a result AMS is selling the 50 trim as its smallest turbo instead of the 3071.
I don't expect that putting a 3076 or 50 trim will net me a whole lot of power, but it should net me the additional 15-20 wtq that I'm looking for past 7500 rpm.
l8r)
Old Apr 7, 2006 | 10:31 AM
blkAMSevo8's Avatar
Straight 93
