HKS 272 ex cam on IX
Old Aug 1, 2006 | 02:33 PM
  #46
trinydex's Avatar
HAHAHHAa
Old Aug 1, 2006 | 02:34 PM
  #47
freshevo8's Avatar
YOu really would have expected 400whp on pump gas with just the basic mods and cams? We haven't seen any other IX hit 375 with those mods, so I don't know where your high expectations came from. Did you think this car had a lot more mods or something? People haven't hit 400whp on alky and big boost, so I wouldn't have expected it on pump gas with the cams either. Unfortunately, we haven't seen ANOTHER IX make this power with the cams yet...
oops. went back and read the TT section and realized they didn't have alky. i was thinking they used alky with the cams for some reason. been awhile since i've read it. i'm a turd.......
Old Aug 1, 2006 | 05:49 PM
  #48
statix's Avatar
Originally Posted by RenoEvo
Dude READ THE POSTS. He said 23psi in post #32
DUDE, why dont you go back and read post #21, where he specifically says he is boosting to 26psi and holding 23 steady
Old Aug 7, 2006 | 01:27 PM
  #49
stikillller's Avatar
what if i get a hks 272 ex cam and 280 TT intake cam? I can do that right?
Old Aug 7, 2006 | 03:44 PM
  #50
High_PSI's Avatar
JUN put one on their IX, worked for them, a 260 Exhaust cam.
Old Aug 7, 2006 | 03:52 PM
  #51
TTP Engineering's Avatar
264's have worked for us.
Old Aug 7, 2006 | 03:54 PM
  #52
trinydex's Avatar
yeah but why would you want to?
Old Aug 7, 2006 | 05:41 PM
  #53
veilsidefd3s87's Avatar
Well all I know is that my 280exhaust cam didn't do much for me, especially going to the local 1/8th of a mile. Because before with just "tbe, drop in filter, boost controller and I kept running 8.0 and trapping 92 mph.......after the 280 race cam install went back and still hit the 8.0's and trapping 1 mph more. But yeah I guess hks is coming out with some cams for ix and a controller so we'll see what happeneds.
Old Aug 8, 2006 | 07:00 PM
  #54
SmokinJoe's Avatar
I was one of the first to show my IX's dyno with a 272cam. - I still believe it's offered at least 10whp. Minimum.
I've yet to see a dyno a strong as mine. 21psi, Flashed with intake and full exh.
This graph is with 3gal of 100ct and 26psi. Again - very solid numbers.
Can anyone present a graph of a IX with an intake and full exh, at 26psi - turning in more than 380wtq?
I still believe the cam helps.
Old Aug 8, 2006 | 07:16 PM
  #55
Rnm's Avatar
Rnm
https://www.evolutionm.net/forums/sh...d.php?t=173232
Old Aug 8, 2006 | 08:19 PM
  #56
-=SPECTRE=-'s Avatar
joe - it would help if you posted SAE corrected numbers rather than uncorrected
Old Aug 8, 2006 | 08:30 PM
  #57
SiCKlEyWiKeD's Avatar
I'm wondering how many of you have it on the ix's since there isn't an intake cam out, besides TT. I just got the hks 272 ex cam for my bday from a friend, wondering approximatly how many whp this will yield? my mods are
Tanabe Concept G Blue TBE [no cat]
K&n drop in
hallman boost controller [23 psi i believe]
TT flash
i have 325 whp and 301 wtq as of now, anyone who has installed and dyno'd have any idea? Thank you !!!
also, a tune after the cam would yield better #'s then just putting the cam in and no flash right?
Don't tell me you're running that thing without a boost gauge?
Old Aug 10, 2006 | 01:47 PM
  #58
of course i have a boost gauge, 60mm defi with control unit~ hahahaha
i just don't list it as i don't think it really is a "mod"
Old Aug 10, 2006 | 06:03 PM
  #59
High_PSI's Avatar
I made more power with my Pump gas run Vs. your Pump gas run on my 2003 9.8 Hotside evo. You should be way higher ona Dynojet, especially with a CAM.
Although your power curve is better then mine and CERTAINLY better bottom end, I can't wait to get my IX, but your power band just dies on the pump gas run, should be like 360WHP on pump.
Old Aug 10, 2006 | 06:13 PM
  #60
just checking, cuz on your mods you listed 23 psi I BELIEVE. So leads me to wonder if you were guessing your boost.
