Who's 2006 Rattles at Idle?!?
if you have an interior windshield rattle try this
TSB-05-42A-005 Released March 2005 (titled: Winshield creaking noise while driving)
1 Test drive to verify noise is coming from A pillar area
2 use a soft trim stick to remove the side windshield moulding from the cowl trim - do not remove the cowl trim for this procedure
3 obtain adhesive-backed thin felt material from BSR kit (MR991752) Cut six felt pieces, approx 70 mm x 5 mm
4 Remove the liner from the back of the felt pieces. Affix the felt on the inner clips. Affix one felt piece to each of the three inner clips Repear on the other side.
5 Be sure that the outer moulding clips (four on each side) are securely attached to the body retension stud. IF the clips are not properly attached, noise may result
6 Reinstall the windshield side moulding
7 test drive to verify the noise is eliminated.
Takes .4 hrs to do - I recommend everyone with the creak to it asap - I feel like the car has been born again - I didn't realize how much that creak annoyed m
Originally Posted by Dayton Evo
I've seen many rattle after putting a TBE on and it turned out to be the front bumper cover rattling against the bumper support.
where was the one from the TBE's rattling exactly? im just hoping like heck thats the same rattle on my stock one since its from that area!
Trav
mine's rattling from around the lower two pulleys, oil pan or thereabouts...
any ideas on how to resolve this anyone?
anyone had this rattle and fixed it or had a dealership fix it???
almost most noticeable from the drive belt auto tensioner area/pulley but who would know!
Help us out!
Trav
Help us out!
Trav
looks like mine is/most likely the serpentine belt auto tensioner rattling from new
going to get dealership or workshop to replace ASAP
hope they can fix it!!
Trav
Trav
Noticed similar rattling after a 350 mile trek up to CT (only 2K on the car)...but I can't seem to replicate it--just random but sound seems to emanate from under the dash...or it's being translated through the dash (kind'a a weird way to describe it, I know). Mods on my IX are simple: Jun BL cat back, K&N drop in, and e-flash from Al--none of which I can (or would attribute as the cause).
Anyway, it goes away w/a little RPMs...will keep trying to discover what it is and get back to this thread.
