Who's 2006 Rattles at Idle?!?
Old Apr 11, 2006 | 08:01 AM
SilverNine's Avatar
Who's 2006 IX Rattles at Idle?!?
So i get this rattling noise at idle in my 06 Evo. took it to and they said its normal. the sound goes away when i press the clutch and gets louder when i turn ON the a/c! anyone has this problem?
Old Apr 11, 2006 | 08:05 AM
Rnm's Avatar
Rnm
I have a slight rattle as well, but its been like that since the beginning. Not too worried about it as its not a quiet ride.
Old Apr 11, 2006 | 08:08 AM
Ph3n1x's Avatar
Could be the noisy Throw out Bearing on the Clutch., but thats normal. sounds like a little jingling sorta.
Old Apr 11, 2006 | 08:28 AM
skang5's Avatar
I have the same noise, and guess it is normal.....
Old Apr 11, 2006 | 08:36 AM
3000ways's Avatar
Normal dude, don't be so paranoid.
Old Apr 11, 2006 | 10:03 AM
su37su's Avatar
same here its normal I guess.
Old Apr 11, 2006 | 12:57 PM
dominant1's Avatar
....Relax guy, its the old mitsubishi throwout bearing rattle only goes away when clutch pedal is pressed in. Its normal! I get it on my 2000 eclipse gt which now has an aftermarket clutchmasters clutch & throw out bearing and an fadanza light weight flywheel. It still rattles with the after market parts, so its a design flaw, just turn up the music you wont here it anymore.
Old Apr 11, 2006 | 01:35 PM
ray3328's Avatar
If you think that rattle is bad wait till you put a tbe on.
Old Apr 11, 2006 | 01:51 PM
Spooling Dreams's Avatar
off topic: anybody have a TBE sound/video clip?
you got me curious.
Old May 16, 2006 | 12:16 PM
mshain's Avatar
Wink
input bearings, if rattle occurs when car is cold.
Old May 16, 2006 | 12:33 PM
evo3barboost's Avatar
Hi
Have you got a link to that TSB ? I have a 05 Evo 8 and my tranny is making odd noises in line with bearing issues
Old May 16, 2006 | 12:39 PM
gonzstarr's Avatar
Well yes that rattle from your throw out bearing is normal... i had an 8 before and same noise... get a TBE and that noise goes away but others will arise....
also be careful, i had a noise under my hood which i thought was normal on my 9 and it turned out that the bolt that holds the radiator fan in place had sheared off and my fan mas hitting the radiator and making beautiful holes in it, in a circular pattern, which i though was just divine!! yes i got it fixed, almost the same day, it was horrible, coolant everywhere... Mitsu says "it must of came defective from the factory." wow thanks Mitsubishi! So beware!
Old May 16, 2006 | 12:45 PM
pog0's Avatar
My IX doesnt rattle at idle but I do have some weird idle from the passenger side of the car at 2000-2200 RPM and 3000-3200 RPM. Other than that, nothing.
Old May 16, 2006 | 12:48 PM
Rnm's Avatar
Rnm
Curious, but what other noises arises when you put a TBE? I'm on stock exhaust with a test pipe and I've been debating on getting a TBE although quiet such as Buschurs 3" with a Magnaflow muffler.
Old May 16, 2006 | 12:51 PM
TPetsch's Avatar
Could also be the accessory belt idler pulley.
