EvoScan V.90 Is Ready
Old Sep 16, 2006 | 09:14 AM
  #136
nj1266's Avatar
Originally Posted by mchuang
Let me ask you have you ever upgraded the firmware on your wideband? He is using 4.1 and comport 4. and the baudrate is 9600 on the serial cable in device manager.
I upgraded the firmware once a while back. I will check and see if I have the latest firmware and update to the 4.1. Some are saying that you need to disconnect the input cable from the LMA-2 (the device that transmits boos, knock to my LM-1) inorder to get the AFR signal from the LM-1 to log on Evoscan. I have not tested yet and I hope that this is not the case. It will be a setback if it is.
Old Sep 16, 2006 | 12:43 PM
  #137
justchil's Avatar
I'm still wondering how accurate the coolant temp is... today I flushed my coolant out so it was a good time to see what temp evoscan says the thermostat opens. Well it opens somewhere between 212-214f (100-101c) going by evoscan. This seems pretty high to me...
I don't think there were any changes to this from .8 so this could be OT
Old Sep 16, 2006 | 12:55 PM
  #138
TTP Engineering's Avatar
Werent you using the updated forumula?
I changed this in my xml file, but then 0.9 went back to the old formula.
Old Sep 16, 2006 | 01:55 PM
  #139
Rob W.'s Avatar
So what coolant temp formula do you recommend?
Old Sep 16, 2006 | 02:46 PM
  #140
justchil's Avatar
Well on .8 I was subtracting 10* but I must not have changed that in .9.
Looking at the evo manual.. Valve opening temperate is 176+/- 3. I'd assume the fan kicks on the same time the thermostat opens.. could be a problem with my setup I suppose.
Old Sep 16, 2006 | 02:55 PM
  #141
I will try to find it. It is posted in this ecuflash forum somewhere.
I had it posted in DF forums, but in an effort to discredit evoscan so people won't review their knocksums using a DF, he called evoscan inaccurate and deleted the coolant temp formula I had posted. The formula came from another member.
I encourage all of my reflash customers to review the knocksums from my custom tunes.
TTP has nothing to hide unlike others.
Old Sep 16, 2006 | 03:58 PM
  #142
nj1266's Avatar
I tested on the ver 0.8 and my pocketlogger and I found that the Evoscan is off. With the pocket logger the fan kicks in @ 190-192*. With the EvoScan the fan kicks in around 210-212*. That was with version 0.8. I have not tested the version 0.9 yet.
Old Sep 16, 2006 | 04:14 PM
  #143
nj1266's Avatar
So AL is now saying that the KS results are wrong since the coolant temp formula is off That is his way to prevent people from using Evoscan to find out if his tune is knock prone or not. Does he not know that there are a million other ways to detect knock aside from Evoscan
Old Sep 16, 2006 | 05:12 PM
  #144
mchuang's Avatar
Wow some bs, I swear that foo dirty so dam dirty. No other tuners have dirt like him on this forum. Too bad some cannot see the wolf in sheep clothing..
Old Sep 16, 2006 | 07:25 PM
  #145
AlwaysinBoost's Avatar
really... is that why you purchase Megan Racing exhausts and then tell EVOm that they are custom made by your 'fabricator'.
Old Sep 16, 2006 | 07:37 PM
  #146
C6C6CH3vo's Avatar
you mean like mormons? JK I'm a mormon, well - not really. This thread has gone astray, mods?
Old Sep 16, 2006 | 08:43 PM
  #147
MalibuJack's Avatar
Mitsubishi Logger Alpha proof of concept code WORKS.. an alternative logger will be available soon...
https://www.evolutionm.net/forums/sh...d.php?t=223828
Old Sep 16, 2006 | 11:12 PM
  #148
mrfred's Avatar
Here is the coolant temperature correlation that jcsbanks posted from a 1G DSM ECU:
***EDIT: This is the intake air temperature formula***
-0.00000003166xxxxx+0.00001425xxxx-0.002490xxx+0.2143xx-10.279x+361.01
Here is the air temperature correlation:
***EDIT: This is the coolant temperature formula***
-0.0003893xxx+0.08056xx-6.5226x+315.73
There's no guarantee that those eqns are exactly right for an Evo, but they appear to be much closer than the eqns released with EvoScan. Copy them into the Data.xml file just as they are written above.
Old Sep 16, 2006 | 11:44 PM
  #149
justchil's Avatar
Sweet man thanks again
If anyone here has another logger how about comparing this formula to your other logger
Old Sep 17, 2006 | 12:25 AM
  #150
MalibuJack's Avatar
These do work better.. they allow Evoscan to evaluate the data in a nonlinear fashion instead of a simple linear equation.. Unfortunately these calculations create interative loops and slow down evoscan a bit.
