accessport release date?
Old Jan 29, 2007 | 07:01 PM
  #31
EVO MR 28's Avatar
Just talked to a dealer today who said Cobb is aiming for the end of March release date, damn they are slow
Old Jan 29, 2007 | 09:45 PM
  #32
I C Blue's Avatar
Cool
Attached are the dyno plots of my tune from Cobb.
From left to right:
Stage 1 smoothed
Stage 1 detail (AFR, engine noise (volts), torque, boost, HP)
Stage 2 smoothed (TBE)
Stage 2 detail (AFR, engine noise (volts), torque, boost, HP)
Again this is for the 2003 & 2004 Evos w/ 9.8 cm^2 hotside. 2005 + numbers are higher. Couldn't be happier w/ stage 1 & Cobb is awesome to work with!
Attached Thumbnails accessport release date?-cobb-stage-1.jpg   accessport release date?-cobb-stage-1-detail.jpg   accessport release date?-cobb-stage-2.jpg   accessport release date?-cobb-stage-2-detail.jpg
Old Jan 30, 2007 | 06:47 AM
  #33
ultimatesteve's Avatar
I wouldnt hold your breath. I have heard the same thing for a few months now
Old Jan 30, 2007 | 08:25 PM
  #34
Jim in Tucson's Avatar
Blue,
I'm very confused. Your initial post stated that you only have a Cobb Stage 1.
Then you post both Stage 1 and Stage 2 dyno plots of YOUR car.
Then you state again that you only have Stage 1.
Please clarify.
Old Jan 30, 2007 | 11:27 PM
  #35
I C Blue's Avatar
Jim,
They are using my car for beta testing of the stage maps.
Cobb developed a stage 1 map on my otherwise stock 2003 Evo, then installed a prototype TBE and developed a stage 2 map. They put the stock exhaust back on the car so that I could run the stage 1 map for a while to verify that there were no problems with the tune (none yet!).
Old Jan 31, 2007 | 08:12 AM
  #36
Ahh-haa...that sounds pretty clear to me!
Thanks,
Old Jan 31, 2007 | 08:38 AM
  #37
V.8MR's Avatar
I think they intend for me to beta the protuner, as my car has,
Ported & Polished Head,
Ported polished & coated header
Ported & polished wastegate,
Coated 10.5 Hot side,
1/2m oversized Supertec Valves & valve job,
Cosworth Head studs and Mitsubishi Stock MLS Head gasket,
supertec titanium retainers,
supertec dual valve springs,
Supertec Valve seats,
Comp 272's,
AEM cam gears, +1 I, -1 E
Ebay O2 coated,
AMS turboback catless w/a wrapped DP,
Walbro 255,
Apexi Intake,
Evo8 JDM BOV,
Greddy Profec Spec 2 @ 26PSI,
Perrin Fuel Rail
Ultimate Racing 900cc Injectors
So im not sure exactly what i am betaing?
Old Jan 31, 2007 | 11:05 AM
  #38
V.8MR's Avatar
Old Jan 31, 2007 | 11:38 AM
  #39
RallySport Direct's Avatar
Silver Sponsor
Cobb is working hard at getting this product out. I don't believe they are slow they are just very thorough. They had to make sure the new subaru port was perfect before releasing it and that delayed the Evo port. They had NEVER set a release date but more of a estimate for release. They were hoping for the end of january but since the subaru ports did not come out until December it got moved.
The ports will be awesome and many people will love them. In every thread about cobb you will get the ECUflash fan boys saying it is worthless but in every thread I have listed why the cobb is a better product for some people. And in every thread people have agreed that they would choose it over ECUflash for those reasons.
I talk to cobb on almost a daily basis and as soon as the port is available for the evo I will be buying one. Even if the owner make me pay retail to get one of the first ones
Old Jan 31, 2007 | 01:35 PM
  #40
AutoMotoSports's Avatar
I just got off the phone with Trey Cobb and we had a long talk about the production process and release. I think the end of the month is a little optimistic. First of spring or late winter sounds a little more on par with there current schedule.
Right now Cobb has a couple people doing some BETA testing for them and the second a complete unit is available for testing they are sending on to AMS for martin to poke around with.
We are all super excited about the system and I personally can't wait to get one on my car.
Eric
Old Jan 31, 2007 | 03:06 PM
  #41
V.8MR's Avatar
Eric
Are you all even an authorized protuner?
Old Feb 3, 2007 | 12:23 AM
  #42
boostless's Avatar
I've been an advocate for the AP ever since my friend got a few years ago BUT I'm not sure I'm willing to pay $700 for 20hp. Im hoping numbers are MUCH more impressive for the IX
Old Feb 4, 2007 | 06:30 AM
  #43
I C Blue's Avatar
Check out the other AccessPORT thread for Evo VIII RS numbers (10.5 cm^2 hotside).
As Jim stated:
Evo 8 RS:
Stock: 227 HP & 240 lb/ft
Stage1: 266 HP & 248 lb/ft
Stage2: 282 HP & 260 lb/ft
So, gains are:
Stage 1 = 39 HP & 8 lb/ft
Stage 2 = 55 HP & 20 lb/ft
The larger outlet just allows the car to take more boost (I've seen the plots). I imagine that the IX will be even higher. So yes, more substantial gains.
The nice thing about my flash is that the car pulls to redline so much better than stock, where it just kind of quit.
Old Feb 4, 2007 | 06:55 AM
  #44
GeoffM's Avatar
I can't wait any longer.........
