Stationary Rev Limit
Old Jul 5, 2007 | 08:33 AM
Evo_Pma's Avatar
hello
i just got yesterday my tactrix cable so i went to my evo 8 usdm and download the stock map then do a copy of the file and change the stationary rev limiter to 5000rpm(i check with 5500 and 5900 too) then i upload it with the new value but the stationary rev limiter didnt work :S i was with the clutch in and the tranny in 1 gear
There is another thing that i need to change ?
thanks
Old Jul 5, 2007 | 08:39 AM
Evo_Pma's Avatar
when i downloaded the stock rom the stationary rev limiter was in 5000 too !!! thats sounds weird thats why im thinking that have to be anything else that i need to change to active it
Old Jul 5, 2007 | 08:42 AM
bvdawg13's Avatar
hook up to ecuflash, then pull the map out of your car, change the stationary rev limit and send it bak to the ecu and thats all that needs to be done
what year is your evo?
Old Jul 5, 2007 | 08:47 AM
Evo_Pma's Avatar
thats what i did , but for example i downloaded the stock map and check the stationary rev limiter was in 5000 but dosent work and that ecu was never reflashed
i change it to 5500 and 5900 and dosent work either
its a 2003 evo 8 usdm
sorry its a 2005 evo 8 usdm
Old Jul 5, 2007 | 08:50 AM
Evo_Pma's Avatar
check this is the screen shot of the stationary rev limit in the stock rom i didnt change it
Old Jul 5, 2007 | 08:52 AM
bvdawg13's Avatar
maybe there is more to it with the 03's but it doesnt seem right, it should work
jbrennen's Avatar
I'm pretty sure that '03 Evos don't have a stationary rev-limiter. I know that mine does not.
Old Jul 5, 2007 | 08:54 AM
bvdawg13's Avatar
the 03's dont come stock with them, well they do but its set higher than the rev limiter
the 03's can get them if they are flashed for them
Old Jul 5, 2007 | 08:56 AM
Evo_Pma's Avatar
maybe i need to do this?
https://www.evolutionm.net/forums/sh...nary+rev+limit
Old Jul 5, 2007 | 08:58 AM
Evo_Pma's Avatar
well when i check my stock rom was set on 5000 and not higher and that ecu was never reflashed , i am the first that touch that ecu
Old Jul 5, 2007 | 08:59 AM
jbrennen's Avatar
But his image showing the 5000 RPM stationary rev-limiter in a stock '03 ECU -- that's clearly not accurate. Stock '03 Evos certainly don't have a 5000 RPM stationary rev-limit.
Old Jul 5, 2007 | 09:03 AM
Thoe99's Avatar
I have an 03' and I can't get the stat. rev limit to work either.
Old Jul 5, 2007 | 09:06 AM
Evo_Pma's Avatar
yeah thats weird
Old Jul 5, 2007 | 09:23 AM
cpoevo's Avatar
I have an '03 with ID 94170008 and my "Stationary Rev limit" was set higher than the "Rev limit". I just changed the number to what I wanted, reloaded the MAP and it worked no problems. Mine was set at 5750 rpm.
Old Jul 5, 2007 | 10:54 AM
Evo_Pma's Avatar
my ID: 96940011
