The Official Wide Tire Thread
Old Jul 18, 2007 | 08:14 AM
Warrtalon's Avatar
Only post pics, details, and comments/advice about your setup. Reserve comments about others setups for PM's. This is a thread of people who have done "wider than normal" tires and what they have done to achieve this. If you have LARGER THAN 255s, then post up specs and pics.
Include all of the following and maintain the Bold Headings.
Year/Make/Model: 2005 GG MR
Wheels: 18X9.5 Enkei NT03+M +40 w/25mm spacers up front
Tires: 285/30-18 Kumho Ecsta V710 (DOT slicks)
Suspension: Vishnu/Gerrard Ohlins
Alignment: -3.0f/-1.5r 1/16th toe-out front & 0 toe rear
Fenders Rolled or Cut: Heavy rolling front / minor rolling rear
Other Body modifications: None
Advice: Keep it simple, and go with things that are proven to work. Don't just slap together random $200 braces and bars. Do your research, make a plan, and then follow it. Yes, there is more than one way to go fast.
In the event you do not have the specs for one of the "areas" please include it with N/A.
Pictures:
Old Jul 18, 2007 | 08:21 AM
scorke's Avatar
Year/Make/Model: 2003 GSR
Wheels: 17x9.5 +22 Gramlight 57C's with 8mm spacers up front
Tires: 275/40/17 Hoosier Grand-Am CUP Slicks
Suspension: JIC FLTA-2's
Alignment: -2.8f/1.7r 0 Toe
Fenders Rolled or Cut: Rolled Rear (front rolling pending and necessary
Advice: Run 18's if you want to run big slicks, I just happen to love these wheels so I comprimised because I got them for a bargain!!!
Pictures:
^17x8.5 255/40 vs 17x9.5 275/40
Scorke
Old Jul 18, 2007 | 08:30 AM
SuperHatch's Avatar
Year/Make/Model: 2003 Black GSR
Wheels: 17X9 5-Zigen FN01R-C +35 no spacers
Tires: 275/40-17 Falken Azenis 215
Suspension: Megan Racing Street Coilovers, whiteline F&R Swaybars
Alignment: -2.7f/-1.7r 0 toe front & rear
Fenders Rolled or Cut: Heavy rolling rear / no rolling front
Advice: This was a simple setup that netted quick Auto-x times in a SM class. I drove an AS Evo on the OEM tires back to back with this car and my SM car was ~1-2 sec faster on a 30sec course. However, my car was more prone to oversteer and was more difficult to drive at the limit. The stock car felt more composed. If you want the look of wide tires as cheaply as possible, I really don't know of a setup that could be done for less than this. But there are better performance options out there.
Pictures: N/A but will add later.
Old Jul 18, 2007 | 08:39 AM
scorke's Avatar
^ Oh sheezy, the unmodified MR has wheels and tires, so it begins hatch....
Scorke
Old Jul 18, 2007 | 08:51 AM
SuperHatch's Avatar
Scorke
lol, this is the specs on my old car, my 03. My 06 stayed unmodified until the day I got rid of it. I don't own an Evo anymore... but I still felt I should contribute since I have a little bit of knowledge on this subject.
Old Jul 18, 2007 | 12:43 PM
Max Power's Avatar
Year/Make/Model: 2005 EB GSR
Wheels: 17X9 5-Zigen FN01R-C +35 w/ 5mm Spacer in front
Tires: 275/40-17 Falken Azenis 615
Suspension: Cusco Zero 2R
Alignment: -2.6f/-1.5r 0 toe all around
Fenders Rolled or Cut: Only rolled rear
I'll throw up some pictures when I get to the home computer. Another thing I think would be useful would be:
Rubbing? Some in the front (fender liner) and some in the rear - both very minor.
Old Jul 18, 2007 | 10:01 PM
EVOlutionary's Avatar
Year/Make/Model: 2006 RR RS
Wheels: 18x10 +32 WedsSport SA-70/10mm FR spacer (18x9.5 +35 5-Zigen FN01R-C/10mm FR spacer)
Tires: 285/30/18 Hoosier A6 (285/30/18 Advan Neova)
Suspension: Lieber/Tak spec Ohlins
Alignment: N/A
Fenders Rolled or Cut: No rolling front, heavy rolling rear
Old Jul 19, 2007 | 03:48 AM
EVO8LTW's Avatar
Year/Make/Model: 2004 RS
Wheels: 18x9.5 +35 5-Zigen FN01R-C/10mm FR spacer
Tires: 285/30/18 Kumho V710
Suspension: Ohlins
Alignment: over -3 front camber, -1.5 rear camber
Fenders Rolled or Cut: rears rolled
Old Jul 19, 2007 | 06:44 AM
scorke's Avatar
Alignment: N/A
Alignment-N/A are you really that fast?
Scorke
Old Jul 19, 2007 | 07:44 AM
Scorke
It's pretty standard. Can't share specifics, though.
Old Jul 19, 2007 | 01:22 PM
EVO8LTW's Avatar
Alignment: N/A
I'm really surprised that you don't have to roll your front fenders with that set-up. My 285 V710s on 9.5s with an effective +25mm offset just barely clear the fender with the camber plates maxed out. You're running the same camber plates, 1/2" wider wheels, 3mm less offset, 1/2" wider tires, and, based on pictures, a lower ride height.
Old Jul 19, 2007 | 03:52 PM
Because people kept mentioning this, I did a thorough inspection last time I had the front tires off. I DID notice a very small area of the front fender lip, ~ 1" long on the inside edge of the top of the fender lip, where the paint was worn off. I have never seen any evidence of this on the tire (scrapes, paint, wear, etc. . ) My guess is that it does touch under full compression when the tire flexes in just the right way, but is not significant enough to warrant any attention. I never would have noticed it if I had not specifically looked for it.
EVOlutionary
Old Nov 16, 2007 | 12:48 PM
boomn29's Avatar
BUMP for more entries!
Old Dec 20, 2007 | 03:42 AM
AWDTurbo4's Avatar
Old Jan 28, 2008 | 08:42 PM
KeithD's Avatar
Great pics guys
