ECU does add timing...discuss
Old Jan 15, 2008 | 12:58 AM
  #31
RazorLab's Avatar
Ding ding ding
Old Jan 15, 2008 | 10:00 AM
  #32
honki24's Avatar
lol all this secrecy. I'm in the dark.
Old Jan 15, 2008 | 11:09 AM
  #33
Nuked's Avatar
Comparing to a Subaru, would that mean there is a value in our ECU similar to the Subies Ignition Advance Multiplier (IAM)? Something has to tell the ECU to access the tables.
SQ
Old Jan 15, 2008 | 01:33 PM
  #34
smartbomb's Avatar
Conversly, ever notice that every once and awhile the timing dips into negative numbers even if you have no negative numbers anywhere in any of your maps?
Old Jan 15, 2008 | 02:50 PM
  #35
Thoe99's Avatar
I've seen this happening in my '03 too. I'll have timing set to 15 at 7000rpm, but then the logs show 16 there, and also knock. I tell myself there was a reason I put it to 15 degrees
Old Jan 15, 2008 | 02:55 PM
  #36
RazorLab's Avatar
Again, we are not talking about at WOT in this thread.
Do you have 15* from 100 to max load in your map at 7k? You sure you weren't just seeing interpolation between load cells?
Old Jan 15, 2008 | 09:05 PM
  #37
Thoe99's Avatar
I hit 204 load at 7000rpm and in my timing table, I have that set to 15 degrees. You are probably right about the interpolation though, since I have load 180 set to 18 degrees.
Old Jan 16, 2008 | 02:49 PM
  #38
Slo_crx1's Avatar
Originally Posted by al\lupo
Yep, I'm just investigating and found this thread
I will try a less aggressive MIVEC next.
Btw, with low det cruise map do you mean this?
I have this map on my 94170015 '03 model rom, but EcuFlash has it listed as "Boost Enhancement Advance/Retard (anti-lag)" map. There are 2 in total, map 1 has all 0's in the columns, and map 2 has a slight advance section between the 30-80% load columns from 1500-4000 rpm's. As I've been having a "mystery" knock around the 3000 rpm range, maybe I'll play with this table when it's nicer and see what it affects.
Old Jan 16, 2008 | 04:35 PM
  #39
Pd1's Avatar
Pd1
The Cobb Access Port, of all things, has the elusive ignition advance tables defined btw.
Old Jan 16, 2008 | 09:26 PM
  #40
monsta's Avatar
I can confirm that adjusting this map DOES have an effect on the cells modified when there is no knock.
Im going to try higher load cells of the low det timing advance map with my 91oct map ,but put 93oct in the tank and see if it will advance with the lack of knock. I will post the results if it works as expected.
Old Jan 17, 2008 | 04:26 AM
  #41
C6C6CH3vo's Avatar
Originally Posted by Jorge T
Ok I'm lazy you're right I did not look..I did now, but if load log is close to 2byte looks like he is in closed loop timing advance. I've seen timing in mine advace up to 40* at 40% load . There must be a table for limits on this somewhere.
At 40% the EGR is operating diluting the mix, this slows the burn with CO2 and the ecu possibly advances by the "BE" advance table. MAF will see a drop in airflow and so less fuel is used.
When peopl rescale their timing maps affecting the 40% range they often forget to adjust the BE tables which use the sma load axis
Old Jan 17, 2008 | 06:08 AM
  #42
Jorge T's Avatar
Which "BE" table are you referring too?
Old Jan 17, 2008 | 04:34 PM
  #43
Slo_crx1's Avatar
So it would probably just be a good idea to set all the BE tables to "0" then? Would probably make things easier tuning-wise.
Old Jan 17, 2008 | 05:38 PM
  #44
JohnBradley's Avatar
Interesting stuff. I had been thinking that we might be able to use this in some way akin to the Subaru Timing Multiplier (well really addition algothrim) and let the car run max timing it will take at all times and alter the the timing pulled with knock (more even if desired). All depends on how it develops overall I guess. If I can manage to find the tables the old fashioned way then I will start experimenting. I had known the Cobb had these defined but I wasnt going to mention it since I wasnt sure if they use them for a similar purpose or not.
Old Jan 17, 2008 | 09:09 PM
  #45
Nuked's Avatar
Could the "octane" value be tied into this?
SQ
