Crush the IX BOV?
Old Apr 29, 2008 | 11:05 AM
MR Turco's Avatar
mines not crushed and holds 25/26.
Old Apr 29, 2008 | 11:29 AM
RazorLab's Avatar
The IX bov's seem to be all over the place on what they will hold.
I have seen some not be able to hold 24psi, some won't hold 27psi, etc etc
By hold I mean holding that boost to fuel cut off, not peak boost.
Old Apr 29, 2008 | 01:44 PM
Turbo Kyle's Avatar
Originally Posted by sparky
Kyle: Use a 16-17mm socket with standard wall thickness(not an impact socket).
EDIT: I've run mine to 27 PSI.
And how far should I crush it in?
Old Apr 29, 2008 | 03:39 PM
Tarmacisback69's Avatar
i had a turbosmart 50/50 but made me idle like ****, i crushed the stock dv and plan to run meth @ 30 psi will see how it works out.
Old Apr 29, 2008 | 09:06 PM
Turbo Kyle's Avatar
Ok guys I crushed it almost to where the nipple hits the bottom (bout .200 left). I have more room if I need to crush it more when I get the meth. I run 24 psi on pump...I think it may have been leaking cause the car hits harder on the boost spike...it feels better for sure...I have not got any shutter so far.
Old Apr 29, 2008 | 09:32 PM
sparky's Avatar
Kyle: I am still not clear on just how much you actually crushed it. I crushed mine about 3/16". But, I think that I went a bit too far, as it flutters noticeably on low RPM, light throttle shifts.
Old Apr 29, 2008 | 09:42 PM
Turbo Kyle's Avatar
I crushed it bout 1/2 way...there is not a lot of room in the first place to crush it. I just crushed it a little...17mm socket worked great. I guess I crushed it 3/36
I need to pressure check it though and see when it starts to leak.
Old Jun 22, 2008 | 10:11 PM
eponti's Avatar
Can you post a pic of your crushed bov if possible.I need to crush mine too.
Old Jun 22, 2008 | 10:42 PM
sparky's Avatar
eponti: You need to be real cautious. Just indent it about 1/8-3/16".
Old Jun 22, 2008 | 10:47 PM
mitsuboost30's Avatar
crush it to where the pressure nipple on the top is almost level with the rim...
Old Jun 22, 2008 | 11:02 PM
eponti's Avatar
Did you guy's used a vise to crush it?
Old Jun 22, 2008 | 11:18 PM
sparky's Avatar
Definitely use a bench vise with some wood strips or rawhide on the vise jaws so as not to damage the aluminum. Place the DV in the vise jaws and center a 17mm socket over the top of the DV. Tighten the vise down just a wee bit. Take it out and try it. Better to crush a little bit and then test it on the car.
Old Jun 22, 2008 | 11:46 PM
dsmdeliveryboy's Avatar
I dont get why people talk about the MR dv and IX dv being different theyre EXACTLY the same. The IX dv is rated at 25psi, someone was telling me about this bov you can buy and its the same thing as the IX bov but just a stiffer spring and holds more boost (up to 30 i think it was)
Old Jun 23, 2008 | 09:29 AM
06RS's Avatar
You may be referring to the WORKS DV
http://www.worksevo.com/store/produc...roducts_id=265
Old Jun 23, 2008 | 10:10 AM
LilRico's Avatar
Damn... $199... wow...
