Detailed mapping of Periphery bits underway
Old May 8, 2008 | 06:35 AM
dudical26's Avatar
mrfred - keep up the good work, we all really appreciate it.
I have been wanting someone to figure this out for a while, I'm glad your on the case!
Old May 8, 2008 | 09:48 AM
mrfred's Avatar
Originally Posted by l2r99gst
Not sure if you wanted these labeled or not, but since they weren't:
P0421 Warm up catalyst efficiency below threshold
P0510 Closed throttle position switch
Thanks, I'll update my notes. :-)
Old May 8, 2008 | 10:41 AM
dryad001's Avatar
Originally Posted by honki24
DING DING DING DING DING!!!
+1
Old Jun 19, 2008 | 08:28 PM
draconx's Avatar
mrfred hows this coming along?
Old Jun 20, 2008 | 06:22 AM
fostytou's Avatar
EvoM Community Team
I don't know if it helps in any way (I'm guessing it doesn't) but I can show you how it checks for/works in dsmlink
Old Jun 20, 2008 | 07:28 AM
mrfred's Avatar
Thanks, but I can now see where each of the periphery bits controls various subroutines, so that part is handled. There are several hundred references to the periphery bits in the ROM code, so the actual challenge now is understanding what each of these subroutines or functions does. Ack!
Old Jul 19, 2008 | 08:33 AM
mfr122887's Avatar
Any luck with finding a way to disable the PO300 code?
Old Aug 30, 2008 | 04:43 AM
mrfred's Avatar
The latest version of my periphery bits mapping is attached. I've found a few more things:
1) How to disable ign retard during warmup
2) How to disable EGR-enabled ign advance routine
Old Sep 5, 2008 | 12:52 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Another way is to set only flags.
ROM 88590015 - I guess any ROM
0000101C Enable_Periphery_Checks: 0/1 - enables/disables checks Periphery 2,3,4
0000101D Enable_O2_Frequency_Ratio_Check: 1
0000101E Enable_O2_Slow_Response_Check: 1
0000101F ? 1
00001020 ? 1
00001021 Enable_O2_Voltage_Check: 1
00001022 Enable_AFR_Check: 1
00001023 Enable_Idle_Control_Check: 1
00001024 Enable_Intake_EGR_MAP_Check: 1
00001025 Enable_Evaporative_Checks: 1
Old Sep 5, 2008 | 04:36 AM
acamus's Avatar
Current Periphery bit arrays are available thru
MUT_D0_RAM_Periphery_00
MUT_D1_RAM_Periphery_0
MUT_D2_RAM_Periphery_1
MUT_D3_RAM_Periphery_2
MUT_D4_RAM_Periphery_3
Old Sep 5, 2008 | 04:47 PM
Dapper Dan's Avatar
very nice man!
Old Jan 22, 2009 | 06:50 PM
Darwinn's Avatar
Any chance to disable P0710 through periphery bit? I have switched from 6speed EDM (88840017) with Transmission fluid temperature sensor to 5speed without it. I dont want to keep sensor connected to ecu if possible.
Also same with rear o2 sensor. Maybe someone found how to completely disable P0141 check through bits..
Old Mar 7, 2009 | 09:22 AM
Danieln's Avatar
Hi Mr Fred,
Today I switch my ROM 88840013 (USDM) to ROM 88840017 EDM stock version.
My car was bought from EUROPE but the ROM show`s USDM in Ecuflash.
The new version ROM 88840017 is more detailed inside because the last one has less opened options inside.
Do I must change something into the new map in order to be sure that everything works propper using periphety mode?
Please tell me if within this map v1.7, I can remove the "check engine/service engine light (trouble code) without removin it complitely from the car.
Thank you
Old Mar 23, 2009 | 04:05 PM
ExViTermini's Avatar
So I guess if we disable bit 4 of FCA then the p0300 will plague us no more?
EFDF to EFCF bit 4 is the only diff.
Old Mar 23, 2009 | 04:11 PM
GST Motorsports's Avatar
Originally Posted by Darwinn
I have switched from 6speed EDM (88840017) with Transmission fluid temperature sensor to 5speed without it. .
The EDM 6spd has a trans temp sensor? really? That is very interesting.
