Asus Eee issues
Old Jul 15, 2008 | 09:52 PM
RazorLab's Avatar
Do you also have ecuflash on the Eee? Does that work fine with the cable?
Do you have the newest version of MS framework or whatever it's called?
Old Jul 15, 2008 | 10:51 PM
oldevodude's Avatar
It's called .net Framework or (dot net framework) 2.0 is latest for XP me thinks.
Old Jul 15, 2008 | 11:24 PM
RazorLab's Avatar
Thanks , I couldn't for the life of me remember the exact name at the time of the post, guess I am getting old.
Old Jul 17, 2008 | 07:29 PM
Eastside's Avatar
Don't have Ecuflash installed yet.
Should I try the new version or should I use an older one that we know works with this little computer?
I'll find out what version of the .net framework I'm using.
If I can anyway.
another post sooner than later I hope.
Old Jul 17, 2008 | 10:11 PM
Eastside's Avatar
.net framework 2.0
Evoscan .99 still does the same thing
When I figure out what Ecuflash to try I will to test the cable/drivers.
Hm.
Do you know what .net framework you're using on your Eee razorlab?
Old Jul 19, 2008 | 04:46 PM
Eastside's Avatar
Installed Ecuflash 1.29
No go.
Drivers maybe?
Somehow they got messed with when I installed ecuflash.
I reinstalled them, same issue.
Where do I go from here?
Anyone?
Please?
Old Jul 19, 2008 | 06:15 PM
RazorLab's Avatar
Is the cable recognized in Device Manager?
Old Jul 19, 2008 | 07:05 PM
Eastside's Avatar
Yep.
Old Jul 19, 2008 | 09:55 PM
Eastside's Avatar
Could my only having 1 gb of ram have anything to do with it?
I noticed when searching others have 2 gb's.
Has anyone else got one of these EeePc 900's to work?
Old Jul 19, 2008 | 11:07 PM
RazorLab's Avatar
Mine worked fine with the default 512mb. Now I have 2gb
My EeePc is the first one, 700?
Old Jul 20, 2008 | 09:07 AM
Eastside's Avatar
Hmm.
I'm a little lost as what to try now.
This sort of sucks.
Old Sep 24, 2008 | 11:13 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Same problem but with eeepc 1000. It has nothing to do with drivers.
EvoScan and Scantech are having problems.
The problem is solved once Super Hybrid engine of eeepc is set to high performance.
Then everything works as expected/charm.
EcuFlash is working in any mode. (Colby, great job)
I accidentally found this out, when I thougth the battery is not supplying enough voltage to USB and created car power supply for ligther socket.
Old Oct 12, 2008 | 10:38 PM
merlin.oz's Avatar
Got an ACER Aspire One on Friday, runs XP home.
Installed EcuFLASH v1.39 and dotnet framework 3.5.
EcuFLASH and Mitsulogger both work fine.
Old Apr 27, 2009 | 08:21 AM
fixem2's Avatar
merlin, on your aspire one, have you noticed anything regarding the log timestamp? I ask this becuase when i started logging with my aspire one Datalog lab shows me down on power by 40hp. I looked at some old logs and the timestamps on the Aspire are 1 full second slower for a 3rd gear pull. Yet when I look at the speed I am faster then the old runs by about 3mph. Doesn't make sense.
Was wondering if it was a Laptop thing or an Evoscan install thing. I need to find my old laptop and compare.
evovin
26
Dec 13, 2007 03:24 PM
kaput16
13
Nov 5, 2004 04:50 PM
AmOniaK
Jul 30, 2004 06:02 PM
phreakypat
Apr 16, 2004 12:59 PM
